Processing dataset on NodeMicMac
I tried to process a dataset on the NodeMicMac, but unfortunately it was not succesful. Since i red somewhere, that we should report errors, I gladly do this. Here is my console output:
https://www.dropbox.com/s/2juav924ofvd884/console.txt?dl=0
WEBODM tells me: “An orthophoto could not be generated. To generate one, make sure GPS information is embedded in the EXIF tags of your images, or use a Ground Control Points (GCP) file”
but the Images are from a DJI Mavic and do have GPS Information
Edit: Sorry, I postet the wrong conlose.txt at first. now I did correct that.
I have the same problem when using node micmac. Strange. My jpgs are all geotagged.
Might be a bug; I would open an issue on https://github.com/dronemapper-io/NodeMICMAC/issues
