Great forum and I’m excited for ODM to work. I’ve ran a 99 image dataset twice and experienced a Code 1 notification each time. I’m hopeful you all can help.
PC Hardware:
Lenovo Thinkpad P1, 32 GB, twin SSDs and Windows 10 Workstation
Drone and Sensor Hardware:
3DR Solo, Tower app, 250 AGL collection height, 3 sec/image rate, manually flown, est. 60-80% overlap
GoPro Hero 4 Silver, Peau Productions 8.25 mm lens, 8.25 mm focal length, full resolution, square image (no distortion)
Processing workflow:
Georeference with Geosetter
Import images (99 @ ~7MB each) with ODM
Process using default settings - receive Code 1 error
I have a hunch that the error code is in relation to the discrepancy between the Camera’s EXIF data and my actual lens focal length (8.25 mm). Can I change that setting? Other thoughts? I can provide a few sample images if requested. Thanks!
