Greetings fellow creators!
I searched and did not see a related topic.
Is there a simple way for a non computer programmer (perhaps with some assistance) to create a (MS DOS “like” batch file) to process a list of datasets sequentially with either the same or different processing inputs? I have dabbled in MS VBA so I am in no way a programmer. My last formal exposure to a programming language was Fortran77.
Some basic flow of the code (as I see it )
Run Dataset A [parameters]
ODM processes…
ODM completes processing Dataset A
Run Dataset B [parameters]
ODM processes…
ODM completes processing Dataset B
Run Dataset C [parameters]
ODM processes…
ODM completes processing Dataset C
and so on down the list
My datasets and parameters look like this:
run “E:/Meshroom/Norland_RD_2020_06” --build-overviews --fast-orthophoto --feature-quality ultra --pc-las --pc-quality ultra --skip-3dmodel --time --auto-boundary
run “E:/Projects/KORC_Field_2018_05_14_planar” --build-overviews --feature-quality ultra --pc-las --pc-quality ultra --skip-3dmodel --time --auto-boundary --sfm-algorithm planar
run “E:/Projects/KORC_Field_2018_05_14_planar .84-3” --feature-quality high --max-concurrency 14 --orthophoto-png --pc-quality high --rerun-from dataset --resize-to-1–skip-3dmodel --time
run “E:/Projects/KORC_Field_2018_05_14_planar .84-2” --feature-quality high --matcher-distance 50 --matcher-neighbors 30 --max-concurrency 14 --min-num-features 32000 --orthophoto-png --pc-quality high --rerun-from dataset --resize-to -1 --skip-3dmodel --time
I am just trying to avoid dead time on the processing PC between completion and my giving the command to start the next dataset to process.
Thanks in advance!
Jeff
