I installed ODM on Ubuntu 20.4 in a docker container (ASUS VivoBook laptop, cpu i7-8565U, gpu UHD Grphics 620, 8 GB RAM.).
I tried differen smallt image sets (10-40 images) but the process fails at the same point. The command to start odm:
docker run -it --rm \
-v "$(pwd)/images:/code/images" \
-v "$(pwd)/odm_orthophoto:/code/odm_orthophoto" \
-v "$(pwd)/odm_texturing:/code/odm_texturing" \
opendronemap/odm
The output:
[INFO] Initializing ODM - Sun Jan 31 18:05:28 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: code
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] project_path: /
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /code/images
[INFO] Loading 11 images
[INFO] Wrote images database: /code/images.json
[INFO] Found 11 usable images
[INFO] Parsing SRS header: WGS84 UTM 34N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 5472px
[INFO] ['use_exif_size: no', 'flann_algorithm: KDTREE', 'feature_process_size: 2736', 'feature_min_frames: 8000', 'processes: 8', 'matching_gps_neighbors: 8', 'matching_gps_distance: 0', 'optimize_camera_parameters: yes', 'undistorted_image_format: tif', 'bundle_outlier_filtering_type: AUTO', 'align_orientation_prior: vertical', 'triangulation_type: ROBUST', 'feature_type: SIFT', 'use_altitude_tag: yes', 'align_method: auto', 'local_bundle_radius: 0']
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata "/code/opensfm"
2021-01-31 18:05:29,724 INFO: Extracting EXIF for DJI_0023.JPG
2021-01-31 18:05:29,827 INFO: Extracting EXIF for DJI_0042.JPG
2021-01-31 18:05:29,931 INFO: Extracting EXIF for DJI_0024.JPG
2021-01-31 18:05:30,029 INFO: Extracting EXIF for DJI_0025.JPG
2021-01-31 18:05:30,120 INFO: Extracting EXIF for DJI_0022.JPG
2021-01-31 18:05:30,208 INFO: Extracting EXIF for DJI_0041.JPG
2021-01-31 18:05:30,310 INFO: Extracting EXIF for DJI_0026.JPG
2021-01-31 18:05:30,402 INFO: Extracting EXIF for DJI_0043.JPG
2021-01-31 18:05:30,491 INFO: Extracting EXIF for DJI_0039.JPG
2021-01-31 18:05:30,581 INFO: Extracting EXIF for DJI_0038.JPG
2021-01-31 18:05:30,673 INFO: Extracting EXIF for DJI_0040.JPG
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm detect_features "/code/opensfm"
2021-01-31 18:05:31,826 INFO: Extracting ROOT_SIFT features for image DJI_0023.JPG
2021-01-31 18:05:31,827 INFO: Extracting ROOT_SIFT features for image DJI_0042.JPG
2021-01-31 18:05:31,827 INFO: Extracting ROOT_SIFT features for image DJI_0024.JPG
2021-01-31 18:05:31,827 INFO: Extracting ROOT_SIFT features for image DJI_0025.JPG
2021-01-31 18:05:31,827 INFO: Extracting ROOT_SIFT features for image DJI_0022.JPG
2021-01-31 18:05:31,827 INFO: Extracting ROOT_SIFT features for image DJI_0026.JPG
2021-01-31 18:05:31,828 INFO: Extracting ROOT_SIFT features for image DJI_0043.JPG
2021-01-31 18:05:31,828 INFO: Extracting ROOT_SIFT features for image DJI_0041.JPG
2021-01-31 18:05:32,729 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,778 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,784 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,813 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,818 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,829 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,842 DEBUG: Computing sift with threshold 0.1
2021-01-31 18:05:32,859 DEBUG: Computing sift with threshold 0.1
/code/SuperBuild/src/opensfm/bin/opensfm: line 12: 50 Killed "$PYTHON" "$DIR"/opensfm_main.py "$@"
File "/code/run.py", line 69, in <module>
app.execute()
File "/code/stages/odm_app.py", line 83, in execute
File "/code/opendm/types.py", line 360, in run
File "/code/opendm/types.py", line 341, in run
File "/code/stages/run_opensfm.py", line 32, in process
File "/code/opendm/osfm.py", line 274, in feature_matching
self.run('detect_features')
File "/code/opendm/osfm.py", line 27, in run
system.run('%s/bin/opensfm %s "%s"' %
File "/code/opendm/system.py", line 79, in run
Exception: Child returned 137
Any idea to solve this issue?
