Hi
I’m Haris new to webodm.I have tried processing our drone images in webODM resulting in error ValueError: invalid literal for int() with base 10: ’ ’ in georeferencing. Have tried with both ellipsoidal and MSL but the error resulting is same. The following the specification of camera and geotags:
Camera model:DSC-RX100M2
Latitude,Longitude-DegreeMinutesSeconds
Height(Egm2008).
I’m attaching error log screenshot and sample images ![ODM|690x144]
Hi Piero,
Hope doing well.
I have tried different geotagging method from our end, but couldn’t resolve the issue.
can you guide me on this issue if possible?
Hey @omnaath sorry for the late reply; thanks for sharing the images.
The root problem is that your GPS GPSAltitudeRef EXIF tags are improperly set to empty string (’’). That is not a valid value for that field. I recommend using ddb setexif (setexif — DroneDB 1.0.0 documentation) to set the GPS info for images. It will take care of setting the proper tags.
