Process exited with code 132
Team,
I have installed the webodm on ubuntu 16.04 following the instruction only to get the following error, please point me to the solution if possible.
Hey @tmiles003 sorry about the late reply.
Could you post a little bit more information about the error (a copy of your task’s output, the images you processed, the settings you used, how you installed WebODM, etc.)
Also note that code 132 means that your computer might be too old to run the pre-built images of OpenDroneMap / WebODM. You might have to either use a more recent computer or compile the program from sources (requires some time and technical skills).
