Hello fellow members,
I am need of your help!!!
I have a set of images that cover a large extent of a walking track site, 1317692.0m2 to be exact. Due to limited time and batteries, I had to squeeze this mission into a single battery life by raising the altitude to 200m (something I had never done before) and decrease the frontal and side overlap to 30%.
I am trying to process the images as per the task default settings (what I normally do) but the process takes no more than 10 minutes with the resulting map showing a fraction of the mapped area.
I have tried processing this in segments, groups of 20 images, but thats when the error “Process exited with code 1” appears.
I am simply after geoTIFF and no other assets.
Can you please advise on what the best way to do this would be and how I should approach the task output function (excuse my ignorance, I am still a novice at this).
I am using a mavic 2 pro and running webodm through docker on macos.
This is the google drive link to the images I am using:
https://drive.google.com/drive/folders/1ouJ64XhN7Ci9iNRzjOXozc7RCiB2IOx1?usp=sharing
