Goodmorning everyone.
I’m new to WebODM. I’ve some problem. Any process ends with “exit code 1”. I report below the “task output”.
Thanks to those who will be able to help me. I’m analyzing some images taken with the Mavic Air and there are about 290 photos. My pc has 32 GB of Ram. Thanks again.
Task of 2020-10-15T06:14:44.928Z 291 00:13:37
Process exited with code 1
Task Output:
Created on: 15/10/2020, 08:14:53
Processing Node: node-odm-1 (manual)
Options: rerun-from: dataset, fast-orthophoto: true
… output truncated at 500 lines …
2020-10-15 06:58:35,278 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.921603e+02, Final cost: 3.885125e+02, Termination: CONVERGENCE
2020-10-15 06:58:35,278 INFO: Adding DJI_0826.JPG to the reconstruction
2020-10-15 06:58:35,284 INFO: -------------------------------------------------------
2020-10-15 06:58:35,286 INFO: DJI_0600.JPG resection inliers: 29 / 34
2020-10-15 06:58:35,287 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.895643e+02, Final cost: 3.886704e+02, Termination: CONVERGENCE
2020-10-15 06:58:35,287 INFO: Adding DJI_0600.JPG to the reconstruction
2020-10-15 06:58:35,295 INFO: -------------------------------------------------------
2020-10-15 06:58:35,296 INFO: DJI_0713.JPG resection inliers: 18 / 24
2020-10-15 06:58:35,300 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.897768e+02, Final cost: 3.888973e+02, Termination: CONVERGENCE
2020-10-15 06:58:35,300 INFO: Adding DJI_0713.JPG to the reconstruction
2020-10-15 06:58:35,308 INFO: -------------------------------------------------------
2020-10-15 06:58:35,780 INFO: DJI_0750.JPG resection inliers: 38 / 56
2020-10-15 06:58:35,781 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.909902e+02, Final cost: 3.894980e+02, Termination: CONVERGENCE
2020-10-15 06:58:35,781 INFO: Adding DJI_0750.JPG to the reconstruction
2020-10-15 06:58:35,788 INFO: -------------------------------------------------------
2020-10-15 06:58:35,816 INFO: DJI_0593.JPG resection inliers: 10 / 16
2020-10-15 06:58:35,877 DEBUG: Ceres Solver Report: Iterations: 4, Initial cost: 3.886038e+02, Final cost: 3.885022e+02, Termination: CONVERGENCE
2020-10-15 06:58:35,880 INFO: Adding DJI_0593.JPG to the reconstruction
2020-10-15 06:58:35,886 INFO: -------------------------------------------------------
2020-10-15 06:58:35,888 INFO: DJI_0711.JPG resection inliers: 7 / 15
2020-10-15 06:58:35,892 INFO: DJI_0796.JPG resection inliers: 10 / 11
2020-10-15 06:58:35,942 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 3.881070e+02, Final cost: 3.878340e+02, Termination: NO_CONVERGENCE
2020-10-15 06:58:35,942 INFO: Adding DJI_0796.JPG to the reconstruction
2020-10-15 06:58:35,946 INFO: -------------------------------------------------------
2020-10-15 06:58:35,948 INFO: DJI_0711.JPG resection inliers: 7 / 15
2020-10-15 06:58:35,950 INFO: DJI_0599.JPG resection inliers: 8 / 11
2020-10-15 06:58:35,951 INFO: DJI_0748.JPG resection inliers: 8 / 10
2020-10-15 06:58:35,953 INFO: DJI_0827.JPG resection inliers: 5 / 8
2020-10-15 06:58:35,957 INFO: Some images can not be added
2020-10-15 06:58:35,957 INFO: -------------------------------------------------------
2020-10-15 06:58:35,959 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-10-15 06:58:37,723 INFO: Shots and/or GCPs are well-conditionned. Using naive 3D-3D alignment.
2020-10-15 06:58:47,144 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 3.518230e+03, Final cost: 3.161643e+03, Termination: CONVERGENCE
2020-10-15 06:58:48,643 INFO: Removed outliers: 629
2020-10-15 06:58:49,178 INFO: {‘points_count’: 102250, ‘cameras_count’: 274, ‘observations_count’: 295049, ‘average_track_length’: 2.885564792176039, ‘average_track_length_notwo’: 5.01077306733167}
2020-10-15 06:58:49,178 INFO: Starting reconstruction with DJI_0598.JPG and DJI_0829.JPG
2020-10-15 06:58:49,216 INFO: Two-view reconstruction inliers: 283 / 283
2020-10-15 06:58:49,229 INFO: Triangulated: 283
2020-10-15 06:58:49,233 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 2.280551e+01, Final cost: 1.979903e+01, Termination: CONVERGENCE
2020-10-15 06:58:49,272 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 2.041119e+01, Final cost: 1.918588e+01, Termination: CONVERGENCE
2020-10-15 06:58:49,457 DEBUG: Ceres Solver Report: Iterations: 16, Initial cost: 1.099676e+01, Final cost: 3.944102e+00, Termination: CONVERGENCE
2020-10-15 06:58:49,460 INFO: Removed outliers: 4
2020-10-15 06:58:49,461 INFO: -------------------------------------------------------
2020-10-15 06:58:49,463 INFO: Some images can not be added
2020-10-15 06:58:49,463 INFO: -------------------------------------------------------
2020-10-15 06:58:49,519 DEBUG: Ceres Solver Report: Iterations: 20, Initial cost: 1.257942e+01, Final cost: 3.873973e+00, Termination: CONVERGENCE
2020-10-15 06:58:49,522 INFO: Removed outliers: 1
2020-10-15 06:58:49,524 INFO: {‘points_count’: 279, ‘cameras_count’: 2, ‘observations_count’: 558, ‘average_track_length’: 2.0, ‘average_track_length_notwo’: -1}
2020-10-15 06:58:49,524 INFO: Starting reconstruction with DJI_0596.JPG and DJI_0798.JPG
2020-10-15 06:58:49,538 INFO: Two-view reconstruction inliers: 155 / 155
2020-10-15 06:58:49,546 INFO: Triangulated: 155
2020-10-15 06:58:49,548 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.958413e+01, Final cost: 1.943424e+01, Termination: CONVERGENCE
2020-10-15 06:58:49,564 DEBUG: Ceres Solver Report: Iterations: 3, Initial cost: 1.945978e+01, Final cost: 1.938873e+01, Termination: CONVERGENCE
2020-10-15 06:58:49,654 DEBUG: Ceres Solver Report: Iterations: 23, Initial cost: 7.710442e+00, Final cost: 1.501763e+00, Termination: CONVERGENCE
2020-10-15 06:58:49,656 INFO: Removed outliers: 11
2020-10-15 06:58:49,656 INFO: -------------------------------------------------------
2020-10-15 06:58:49,662 INFO: Some images can not be added
2020-10-15 06:58:49,662 INFO: -------------------------------------------------------
2020-10-15 06:58:49,679 DEBUG: Ceres Solver Report: Iterations: 13, Initial cost: 9.009038e+00, Final cost: 1.375160e+00, Termination: CONVERGENCE
2020-10-15 06:58:49,681 INFO: Removed outliers: 1
2020-10-15 06:58:49,683 INFO: {‘points_count’: 146, ‘cameras_count’: 2, ‘observations_count’: 292, ‘average_track_length’: 2.0, ‘average_track_length_notwo’: -1}
2020-10-15 06:58:49,684 INFO: Reconstruction 0: 274 images, 102250 points
2020-10-15 06:58:49,685 INFO: Reconstruction 1: 2 images, 279 points
2020-10-15 06:58:49,685 INFO: Reconstruction 2: 2 images, 146 points
2020-10-15 06:58:49,685 INFO: 3 partial reconstructions in total.
[INFO] Updating /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm/config.yaml
[INFO] undistorted_image_max_size: 1974
[INFO] Undistorting /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm …
/usr/local/lib/python3.6/dist-packages/sklearn/externals/joblib/externals/cloudpickle/cloudpickle.py:47: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
2020-10-15 06:59:00,470 DEBUG: Undistorting image DJI_0807.JPG
import imp
2020-10-15 06:59:00,470 DEBUG: Undistorting image DJI_0808.JPG
2020-10-15 06:59:00,732 DEBUG: Undistorting image DJI_0809.JPG
2020-10-15 06:59:00,733 DEBUG: Undistorting image DJI_0683.JPG
2020-10-15 06:59:00,981 DEBUG: Undistorting image DJI_0684.JPG
2020-10-15 06:59:01,010 DEBUG: Undistorting image DJI_0682.JPG
2020-10-15 06:59:01,172 DEBUG: Undistorting image DJI_0660.JPG
2020-10-15 06:59:01,237 DEBUG: Undistorting image DJI_0787.JPG
2020-10-15 06:59:01,360 DEBUG: Undistorting image DJI_0685.JPG
2020-10-15 06:59:01,462 DEBUG: Undistorting image DJI_0788.JPG
2020-10-15 06:59:01,547 DEBUG: Undistorting image DJI_0661.JPG
2020-10-15 06:59:01,667 DEBUG: Undistorting image DJI_0789.JPG
2020-10-15 06:59:01,738 DEBUG: Undistorting image DJI_0659.JPG
2020-10-15 06:59:01,876 DEBUG: Undistorting image DJI_0662.JPG
2020-10-15 06:59:01,934 DEBUG: Undistorting image DJI_0806.JPG
2020-10-15 06:59:02,091 DEBUG: Undistorting image DJI_0786.JPG
2020-10-15 06:59:02,134 DEBUG: Undistorting image DJI_0819.JPG
2020-10-15 06:59:02,288 DEBUG: Undistorting image DJI_0785.JPG
2020-10-15 06:59:02,351 DEBUG: Undistorting image DJI_0698.JPG
2020-10-15 06:59:02,493 DEBUG: Undistorting image DJI_0686.JPG
2020-10-15 06:59:02,562 DEBUG: Undistorting image DJI_0820.JPG
2020-10-15 06:59:02,697 DEBUG: Undistorting image DJI_0821.JPG
2020-10-15 06:59:02,781 DEBUG: Undistorting image DJI_0818.JPG
2020-10-15 06:59:02,905 DEBUG: Undistorting image DJI_0776.JPG
2020-10-15 06:59:02,979 DEBUG: Undistorting image DJI_0699.JPG
2020-10-15 06:59:03,117 DEBUG: Undistorting image DJI_0810.JPG
2020-10-15 06:59:03,173 DEBUG: Undistorting image DJI_0700.JPG
2020-10-15 06:59:03,331 DEBUG: Undistorting image DJI_0811.JPG
2020-10-15 06:59:03,382 DEBUG: Undistorting image DJI_0775.JPG
2020-10-15 06:59:03,525 DEBUG: Undistorting image DJI_0777.JPG
2020-10-15 06:59:03,598 DEBUG: Undistorting image DJI_0643.JPG
2020-10-15 06:59:03,744 DEBUG: Undistorting image DJI_0805.JPG
2020-10-15 06:59:03,809 DEBUG: Undistorting image DJI_0663.JPG
2020-10-15 06:59:03,944 DEBUG: Undistorting image DJI_0664.JPG
2020-10-15 06:59:04,025 DEBUG: Undistorting image DJI_0642.JPG
2020-10-15 06:59:04,155 DEBUG: Undistorting image DJI_0641.JPG
2020-10-15 06:59:04,232 DEBUG: Undistorting image DJI_0774.JPG
2020-10-15 06:59:04,353 DEBUG: Undistorting image DJI_0658.JPG
2020-10-15 06:59:04,500 DEBUG: Undistorting image DJI_0681.JPG
2020-10-15 06:59:04,629 DEBUG: Undistorting image DJI_0680.JPG
2020-10-15 06:59:04,699 DEBUG: Undistorting image DJI_0817.JPG
2020-10-15 06:59:04,887 DEBUG: Undistorting image DJI_0773.JPG
2020-10-15 06:59:04,904 DEBUG: Undistorting image DJI_0701.JPG
2020-10-15 06:59:05,119 DEBUG: Undistorting image DJI_0657.JPG
2020-10-15 06:59:05,161 DEBUG: Undistorting image DJI_0790.JPG
2020-10-15 06:59:05,321 DEBUG: Undistorting image DJI_0644.JPG
2020-10-15 06:59:05,392 DEBUG: Undistorting image DJI_0687.JPG
2020-10-15 06:59:05,545 DEBUG: Undistorting image DJI_0772.JPG
2020-10-15 06:59:05,621 DEBUG: Undistorting image DJI_0645.JPG
2020-10-15 06:59:05,774 DEBUG: Undistorting image DJI_0646.JPG
2020-10-15 06:59:05,914 DEBUG: Undistorting image DJI_0771.JPG
2020-10-15 06:59:06,036 DEBUG: Undistorting image DJI_0758.JPG
2020-10-15 06:59:06,134 DEBUG: Undistorting image DJI_0647.JPG
2020-10-15 06:59:06,266 DEBUG: Undistorting image DJI_0759.JPG
2020-10-15 06:59:06,333 DEBUG: Undistorting image DJI_0757.JPG
2020-10-15 06:59:06,475 DEBUG: Undistorting image DJI_0648.JPG
2020-10-15 06:59:06,565 DEBUG: Undistorting image DJI_0656.JPG
2020-10-15 06:59:06,693 DEBUG: Undistorting image DJI_0760.JPG
2020-10-15 06:59:06,769 DEBUG: Undistorting image DJI_0655.JPG
2020-10-15 06:59:06,897 DEBUG: Undistorting image DJI_0756.JPG
2020-10-15 06:59:06,998 DEBUG: Undistorting image DJI_0784.JPG
2020-10-15 06:59:07,097 DEBUG: Undistorting image DJI_0697.JPG
2020-10-15 06:59:07,207 DEBUG: Undistorting image DJI_0761.JPG
2020-10-15 06:59:07,310 DEBUG: Undistorting image DJI_0617.JPG
2020-10-15 06:59:07,414 DEBUG: Undistorting image DJI_0616.JPG
2020-10-15 06:59:07,524 DEBUG: Undistorting image DJI_0618.JPG
2020-10-15 06:59:07,638 DEBUG: Undistorting image DJI_0770.JPG
2020-10-15 06:59:07,773 DEBUG: Undistorting image DJI_0619.JPG
2020-10-15 06:59:07,839 DEBUG: Undistorting image DJI_0679.JPG
2020-10-15 06:59:08,008 DEBUG: Undistorting image DJI_0665.JPG
2020-10-15 06:59:08,040 DEBUG: Undistorting image DJI_0744.JPG
2020-10-15 06:59:08,222 DEBUG: Undistorting image DJI_0816.JPG
2020-10-15 06:59:08,262 DEBUG: Undistorting image DJI_0702.JPG
2020-10-15 06:59:08,458 DEBUG: Undistorting image DJI_0769.JPG
2020-10-15 06:59:08,506 DEBUG: Undistorting image DJI_0743.JPG
2020-10-15 06:59:08,659 DEBUG: Undistorting image DJI_0742.JPG
2020-10-15 06:59:08,753 DEBUG: Undistorting image DJI_0741.JPG
2020-10-15 06:59:08,868 DEBUG: Undistorting image DJI_0745.JPG
2020-10-15 06:59:08,992 DEBUG: Undistorting image DJI_0762.JPG
2020-10-15 06:59:09,118 DEBUG: Undistorting image DJI_0649.JPG
2020-10-15 06:59:09,193 DEBUG: Undistorting image DJI_0609.JPG
2020-10-15 06:59:09,379 DEBUG: Undistorting image DJI_0740.JPG
2020-10-15 06:59:09,406 DEBUG: Undistorting image DJI_0608.JPG
2020-10-15 06:59:09,598 DEBUG: Undistorting image DJI_0607.JPG
2020-10-15 06:59:09,636 DEBUG: Undistorting image DJI_0763.JPG
2020-10-15 06:59:09,824 DEBUG: Undistorting image DJI_0606.JPG
2020-10-15 06:59:09,859 DEBUG: Undistorting image DJI_0768.JPG
2020-10-15 06:59:10,044 DEBUG: Undistorting image DJI_0610.JPG
2020-10-15 06:59:10,087 DEBUG: Undistorting image DJI_0739.JPG
2020-10-15 06:59:10,262 DEBUG: Undistorting image DJI_0615.JPG
2020-10-15 06:59:10,287 DEBUG: Undistorting image DJI_0640.JPG
2020-10-15 06:59:10,483 DEBUG: Undistorting image DJI_0822.JPG
2020-10-15 06:59:10,484 DEBUG: Undistorting image DJI_0804.JPG
2020-10-15 06:59:10,699 DEBUG: Undistorting image DJI_0703.JPG
2020-10-15 06:59:10,707 DEBUG: Undistorting image DJI_0639.JPG
2020-10-15 06:59:10,987 DEBUG: Undistorting image DJI_0638.JPG
2020-10-15 06:59:10,987 DEBUG: Undistorting image DJI_0823.JPG
2020-10-15 06:59:11,182 DEBUG: Undistorting image DJI_0637.JPG
2020-10-15 06:59:11,203 DEBUG: Undistorting image DJI_0620.JPG
2020-10-15 06:59:11,378 DEBUG: Undistorting image DJI_0666.JPG
2020-10-15 06:59:11,424 DEBUG: Undistorting image DJI_0835.JPG
2020-10-15 06:59:11,577 DEBUG: Undistorting image DJI_0836.JPG
2020-10-15 06:59:11,645 DEBUG: Undistorting image DJI_0837.JPG
2020-10-15 06:59:11,777 DEBUG: Undistorting image DJI_0678.JPG
2020-10-15 06:59:11,870 DEBUG: Undistorting image DJI_0838.JPG
2020-10-15 06:59:11,979 DEBUG: Undistorting image DJI_0834.JPG
2020-10-15 06:59:12,096 DEBUG: Undistorting image DJI_0833.JPG
2020-10-15 06:59:12,197 DEBUG: Undistorting image DJI_0704.JPG
2020-10-15 06:59:12,318 DEBUG: Undistorting image DJI_0839.JPG
2020-10-15 06:59:12,399 DEBUG: Undistorting image DJI_0667.JPG
2020-10-15 06:59:12,542 DEBUG: Undistorting image DJI_0755.JPG
2020-10-15 06:59:12,591 DEBUG: Undistorting image DJI_0696.JPG
2020-10-15 06:59:12,771 DEBUG: Undistorting image DJI_0778.JPG
2020-10-15 06:59:12,795 DEBUG: Undistorting image DJI_0783.JPG
2020-10-15 06:59:12,987 DEBUG: Undistorting image DJI_0605.JPG
2020-10-15 06:59:13,012 DEBUG: Undistorting image DJI_0636.JPG
2020-10-15 06:59:13,203 DEBUG: Undistorting image DJI_0791.JPG
2020-10-15 06:59:13,209 DEBUG: Undistorting image DJI_0812.JPG
2020-10-15 06:59:13,427 DEBUG: Undistorting image DJI_0746.JPG
2020-10-15 06:59:13,436 DEBUG: Undistorting image DJI_0832.JPG
2020-10-15 06:59:13,639 DEBUG: Undistorting image DJI_0764.JPG
2020-10-15 06:59:13,640 DEBUG: Undistorting image DJI_0792.JPG
2020-10-15 06:59:13,845 DEBUG: Undistorting image DJI_0621.JPG
2020-10-15 06:59:13,845 DEBUG: Undistorting image DJI_0793.JPG
2020-10-15 06:59:14,050 DEBUG: Undistorting image DJI_0779.JPG
2020-10-15 06:59:14,059 DEBUG: Undistorting image DJI_0824.JPG
2020-10-15 06:59:14,261 DEBUG: Undistorting image DJI_0803.JPG
2020-10-15 06:59:14,270 DEBUG: Undistorting image DJI_0840.JPG
2020-10-15 06:59:14,467 DEBUG: Undistorting image DJI_0794.JPG
2020-10-15 06:59:14,483 DEBUG: Undistorting image DJI_0815.JPG
2020-10-15 06:59:14,672 DEBUG: Undistorting image DJI_0722.JPG
2020-10-15 06:59:14,701 DEBUG: Undistorting image DJI_0721.JPG
2020-10-15 06:59:14,890 DEBUG: Undistorting image DJI_0813.JPG
2020-10-15 06:59:14,926 DEBUG: Undistorting image DJI_0720.JPG
2020-10-15 06:59:15,106 DEBUG: Undistorting image DJI_0782.JPG
2020-10-15 06:59:15,153 DEBUG: Undistorting image DJI_0723.JPG
2020-10-15 06:59:15,319 DEBUG: Undistorting image DJI_0724.JPG
2020-10-15 06:59:15,369 DEBUG: Undistorting image DJI_0719.JPG
2020-10-15 06:59:15,540 DEBUG: Undistorting image DJI_0780.JPG
2020-10-15 06:59:15,580 DEBUG: Undistorting image DJI_0781.JPG
2020-10-15 06:59:15,756 DEBUG: Undistorting image DJI_0725.JPG
2020-10-15 06:59:15,794 DEBUG: Undistorting image DJI_0726.JPG
2020-10-15 06:59:16,034 DEBUG: Undistorting image DJI_0622.JPG
2020-10-15 06:59:16,101 DEBUG: Undistorting image DJI_0705.JPG
2020-10-15 06:59:16,251 DEBUG: Undistorting image DJI_0590.JPG
2020-10-15 06:59:16,322 DEBUG: Undistorting image DJI_0765.JPG
2020-10-15 06:59:16,468 DEBUG: Undistorting image DJI_0589.JPG
2020-10-15 06:59:16,544 DEBUG: Undistorting image DJI_0591.JPG
2020-10-15 06:59:16,668 DEBUG: Undistorting image DJI_0677.JPG
2020-10-15 06:59:16,755 DEBUG: Undistorting image DJI_0848.JPG
2020-10-15 06:59:16,879 DEBUG: Undistorting image DJI_0849.JPG
2020-10-15 06:59:16,972 DEBUG: Undistorting image DJI_0668.JPG
2020-10-15 06:59:17,078 DEBUG: Undistorting image DJI_0847.JPG
2020-10-15 06:59:17,192 DEBUG: Undistorting image DJI_0676.JPG
2020-10-15 06:59:17,282 DEBUG: Undistorting image DJI_0850.JPG
2020-10-15 06:59:17,405 DEBUG: Undistorting image DJI_0669.JPG
2020-10-15 06:59:17,489 DEBUG: Undistorting image DJI_0846.JPG
2020-10-15 06:59:17,630 DEBUG: Undistorting image DJI_0675.JPG
2020-10-15 06:59:17,694 DEBUG: Undistorting image DJI_0588.JPG
2020-10-15 06:59:17,842 DEBUG: Undistorting image DJI_0814.JPG
2020-10-15 06:59:17,913 DEBUG: Undistorting image DJI_0718.JPG
2020-10-15 06:59:18,068 DEBUG: Undistorting image DJI_0754.JPG
2020-10-15 06:59:18,105 DEBUG: Undistorting image DJI_0767.JPG
2020-10-15 06:59:18,299 DEBUG: Undistorting image DJI_0654.JPG
2020-10-15 06:59:18,317 DEBUG: Undistorting image DJI_0688.JPG
2020-10-15 06:59:18,504 DEBUG: Undistorting image DJI_0802.JPG
2020-10-15 06:59:18,531 DEBUG: Undistorting image DJI_0861.JPG
2020-10-15 06:59:18,705 DEBUG: Undistorting image DJI_0674.JPG
2020-10-15 06:59:18,738 DEBUG: Undistorting image DJI_0862.JPG
2020-10-15 06:59:18,929 DEBUG: Undistorting image DJI_0860.JPG
2020-10-15 06:59:18,958 DEBUG: Undistorting image DJI_0670.JPG
2020-10-15 06:59:19,170 DEBUG: Undistorting image DJI_0671.JPG
2020-10-15 06:59:19,172 DEBUG: Undistorting image DJI_0859.JPG
2020-10-15 06:59:19,391 DEBUG: Undistorting image DJI_0672.JPG
2020-10-15 06:59:19,391 DEBUG: Undistorting image DJI_0873.JPG
2020-10-15 06:59:19,597 DEBUG: Undistorting image DJI_0872.JPG
2020-10-15 06:59:19,611 DEBUG: Undistorting image DJI_0871.JPG
2020-10-15 06:59:19,807 DEBUG: Undistorting image DJI_0874.JPG
2020-10-15 06:59:19,831 DEBUG: Undistorting image DJI_0875.JPG
2020-10-15 06:59:20,011 DEBUG: Undistorting image DJI_0876.JPG
2020-10-15 06:59:20,039 DEBUG: Undistorting image DJI_0631.JPG
2020-10-15 06:59:20,239 DEBUG: Undistorting image DJI_0673.JPG
2020-10-15 06:59:20,250 DEBUG: Undistorting image DJI_0858.JPG
2020-10-15 06:59:20,459 DEBUG: Undistorting image DJI_0623.JPG
2020-10-15 06:59:20,466 DEBUG: Undistorting image DJI_0604.JPG
2020-10-15 06:59:20,664 DEBUG: Undistorting image DJI_0857.JPG
2020-10-15 06:59:20,676 DEBUG: Undistorting image DJI_0632.JPG
2020-10-15 06:59:20,898 DEBUG: Undistorting image DJI_0738.JPG
2020-10-15 06:59:20,937 DEBUG: Undistorting image DJI_0706.JPG
2020-10-15 06:59:21,134 DEBUG: Undistorting image DJI_0845.JPG
2020-10-15 06:59:21,179 DEBUG: Undistorting image DJI_0870.JPG
2020-10-15 06:59:21,351 DEBUG: Undistorting image DJI_0633.JPG
2020-10-15 06:59:21,397 DEBUG: Undistorting image DJI_0624.JPG
2020-10-15 06:59:21,585 DEBUG: Undistorting image DJI_0625.JPG
2020-10-15 06:59:21,595 DEBUG: Undistorting image DJI_0825.JPG
2020-10-15 06:59:21,808 DEBUG: Undistorting image DJI_0626.JPG
2020-10-15 06:59:21,814 DEBUG: Undistorting image DJI_0831.JPG
2020-10-15 06:59:22,010 DEBUG: Undistorting image DJI_0627.JPG
2020-10-15 06:59:22,027 DEBUG: Undistorting image DJI_0695.JPG
2020-10-15 06:59:22,236 DEBUG: Undistorting image DJI_0689.JPG
2020-10-15 06:59:22,240 DEBUG: Undistorting image DJI_0795.JPG
2020-10-15 06:59:22,447 DEBUG: Undistorting image DJI_0603.JPG
2020-10-15 06:59:22,450 DEBUG: Undistorting image DJI_0717.JPG
2020-10-15 06:59:22,658 DEBUG: Undistorting image DJI_0841.JPG
2020-10-15 06:59:22,668 DEBUG: Undistorting image DJI_0716.JPG
2020-10-15 06:59:22,878 DEBUG: Undistorting image DJI_0842.JPG
2020-10-15 06:59:22,887 DEBUG: Undistorting image DJI_0592.JPG
2020-10-15 06:59:23,097 DEBUG: Undistorting image DJI_0801.JPG
2020-10-15 06:59:23,098 DEBUG: Undistorting image DJI_0628.JPG
2020-10-15 06:59:23,306 DEBUG: Undistorting image DJI_0614.JPG
2020-10-15 06:59:23,308 DEBUG: Undistorting image DJI_0611.JPG
2020-10-15 06:59:23,521 DEBUG: Undistorting image DJI_0587.JPG
2020-10-15 06:59:23,533 DEBUG: Undistorting image DJI_0736.JPG
2020-10-15 06:59:23,721 DEBUG: Undistorting image DJI_0737.JPG
2020-10-15 06:59:23,749 DEBUG: Undistorting image DJI_0586.JPG
2020-10-15 06:59:23,934 DEBUG: Undistorting image DJI_0735.JPG
2020-10-15 06:59:23,960 DEBUG: Undistorting image DJI_0734.JPG
2020-10-15 06:59:24,138 DEBUG: Undistorting image DJI_0612.JPG
2020-10-15 06:59:24,167 DEBUG: Undistorting image DJI_0733.JPG
2020-10-15 06:59:24,379 DEBUG: Undistorting image DJI_0732.JPG
2020-10-15 06:59:24,379 DEBUG: Undistorting image DJI_0613.JPG
2020-10-15 06:59:24,586 DEBUG: Undistorting image DJI_0650.JPG
2020-10-15 06:59:24,605 DEBUG: Undistorting image DJI_0731.JPG
2020-10-15 06:59:24,781 DEBUG: Undistorting image DJI_0651.JPG
2020-10-15 06:59:24,834 DEBUG: Undistorting image DJI_0730.JPG
2020-10-15 06:59:24,995 DEBUG: Undistorting image DJI_0634.JPG
2020-10-15 06:59:25,050 DEBUG: Undistorting image DJI_0851.JPG
2020-10-15 06:59:25,220 DEBUG: Undistorting image DJI_0635.JPG
2020-10-15 06:59:25,264 DEBUG: Undistorting image DJI_0852.JPG
2020-10-15 06:59:25,433 DEBUG: Undistorting image DJI_0853.JPG
2020-10-15 06:59:25,493 DEBUG: Undistorting image DJI_0629.JPG
2020-10-15 06:59:25,651 DEBUG: Undistorting image DJI_0753.JPG
2020-10-15 06:59:25,710 DEBUG: Undistorting image DJI_0854.JPG
2020-10-15 06:59:25,882 DEBUG: Undistorting image DJI_0653.JPG
2020-10-15 06:59:25,999 DEBUG: Undistorting image DJI_0863.JPG
2020-10-15 06:59:26,145 DEBUG: Undistorting image DJI_0855.JPG
2020-10-15 06:59:26,201 DEBUG: Undistorting image DJI_0707.JPG
2020-10-15 06:59:26,370 DEBUG: Undistorting image DJI_0708.JPG
2020-10-15 06:59:26,415 DEBUG: Undistorting image DJI_0864.JPG
2020-10-15 06:59:26,575 DEBUG: Undistorting image DJI_0715.JPG
2020-10-15 06:59:26,645 DEBUG: Undistorting image DJI_0729.JPG
2020-10-15 06:59:26,783 DEBUG: Undistorting image DJI_0630.JPG
2020-10-15 06:59:26,853 DEBUG: Undistorting image DJI_0844.JPG
2020-10-15 06:59:27,024 DEBUG: Undistorting image DJI_0843.JPG
2020-10-15 06:59:27,062 DEBUG: Undistorting image DJI_0714.JPG
2020-10-15 06:59:27,239 DEBUG: Undistorting image DJI_0602.JPG
2020-10-15 06:59:27,265 DEBUG: Undistorting image DJI_0766.JPG
2020-10-15 06:59:27,448 DEBUG: Undistorting image DJI_0709.JPG
2020-10-15 06:59:27,478 DEBUG: Undistorting image DJI_0830.JPG
2020-10-15 06:59:27,651 DEBUG: Undistorting image DJI_0800.JPG
2020-10-15 06:59:27,696 DEBUG: Undistorting image DJI_0601.JPG
2020-10-15 06:59:27,846 DEBUG: Undistorting image DJI_0694.JPG
2020-10-15 06:59:27,934 DEBUG: Undistorting image DJI_0752.JPG
2020-10-15 06:59:28,062 DEBUG: Undistorting image DJI_0751.JPG
2020-10-15 06:59:28,149 DEBUG: Undistorting image DJI_0693.JPG
2020-10-15 06:59:28,293 DEBUG: Undistorting image DJI_0652.JPG
2020-10-15 06:59:28,385 DEBUG: Undistorting image DJI_0690.JPG
2020-10-15 06:59:28,510 DEBUG: Undistorting image DJI_0728.JPG
2020-10-15 06:59:28,577 DEBUG: Undistorting image DJI_0826.JPG
2020-10-15 06:59:28,725 DEBUG: Undistorting image DJI_0600.JPG
2020-10-15 06:59:28,785 DEBUG: Undistorting image DJI_0713.JPG
2020-10-15 06:59:28,941 DEBUG: Undistorting image DJI_0867.JPG
2020-10-15 06:59:29,004 DEBUG: Undistorting image DJI_0866.JPG
2020-10-15 06:59:29,162 DEBUG: Undistorting image DJI_0712.JPG
2020-10-15 06:59:29,213 DEBUG: Undistorting image DJI_0865.JPG
2020-10-15 06:59:29,376 DEBUG: Undistorting image DJI_0710.JPG
2020-10-15 06:59:29,428 DEBUG: Undistorting image DJI_0868.JPG
2020-10-15 06:59:29,614 DEBUG: Undistorting image DJI_0869.JPG
2020-10-15 06:59:29,648 DEBUG: Undistorting image DJI_0749.JPG
2020-10-15 06:59:29,843 DEBUG: Undistorting image DJI_0691.JPG
2020-10-15 06:59:29,846 DEBUG: Undistorting image DJI_0692.JPG
2020-10-15 06:59:30,055 DEBUG: Undistorting image DJI_0750.JPG
2020-10-15 06:59:30,070 DEBUG: Undistorting image DJI_0593.JPG
2020-10-15 06:59:30,278 DEBUG: Undistorting image DJI_0796.JPG
[INFO] running /usr/bin/env python3 /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --points “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm”
[INFO] running /usr/bin/env python3 /code/SuperBuild/src/opensfm/bin/opensfm export_ply --no-cameras “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm”
[INFO] running /usr/bin/env python3 /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --transformation --proj ‘+proj=utm +zone=32 +datum=WGS84 +units=m +no_defs +type=crs’ “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm”
[INFO] Finished opensfm stage
[INFO] Filtering /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm/reconstruction.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal translate -i “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/opensfm/reconstruction.ply” -o “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_filterpoints/point_cloud.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] Writing ODM 2.5D Mesh file in: /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/odm_25dmesh.ply
[INFO] ODM 2.5D DSM resolution: 0.16060000000000002
[INFO] Created temporary directory: /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp
[INFO] running pdal info /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_filterpoints/point_cloud.ply > /tmp/tmpwjmwygoe.json
[INFO] Point cloud bounds are [minx: -128.709549, maxx: 139.773468] [miny: -99.16725159, maxy: 108.5742111]
[INFO] DEM resolution is (1294, 1672), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/mesh_dsm_r0.4542453962342382_x0_y0.tif (max, radius: 0.4542453962342382, resolution: 0.16060000000000002)
[INFO] running pdal pipeline -i /tmp/tmplh8nzs_m.json > /dev/null 2>&1
[INFO] running gdalbuildvrt “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.vrt” “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/mesh_dsm_r0.4542453962342382_x0_y0.tif”
[INFO] running gdal_translate -co NUM_THREADS=2 --config GDAL_CACHEMAX 31.05% /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.vrt /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.tmp.tif
Input file size is 1672, 1294
0
…10…20…30…40…50
[INFO] running gdal_translate -co NUM_THREADS=2 --config GDAL_CACHEMAX 31.05% -outsize 10% 0 /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.tmp.tif /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.small.tif
0
[INFO] running gdal_fillnodata.py -co NUM_THREADS=2 --config GDAL_CACHEMAX 31.05% -b 1 -of GTiff /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.small.tif /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.small_filled.tif
0
10
20
30
40
50
60
70
80
90
100 - done.
[INFO] running gdalbuildvrt -resolution highest -r bilinear “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/merged.vrt” “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.small_filled.tif” “/var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.tmp.tif”
0…10…20…30…40…50
[INFO] running gdal_translate -co NUM_THREADS=2 -co TILED=YES -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 31.05% /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/merged.vrt /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/tiles.tif
0
…10…
.20…30.
…40…50
…60…
.70…80.
…90…100 - done.
[INFO] Completed mesh_dsm.tif in 0:00:01.038990
[INFO] Sampling points from DSM: /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/mesh_dsm.tif
[INFO] running /code/SuperBuild/src/dem2points/dem2points -inputFile /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/mesh_dsm.tif -outputFile /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/dsm_points.ply -skirtHeightThreshold 1.5 -skirtIncrements 0.2 -skirtHeightCap 100
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/tmp/dsm_points.ply --out /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/odm_25dmesh.dirty.ply --depth 10 --pointWeight 4 --samplesPerNode 1.0 --threads 1 --linearFit
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/odm_25dmesh.dirty.ply -outputFile /var/www/data/5a51ceba-6959-45fe-a03c-1a8ba66dbeff/odm_meshing/odm_25dmesh.ply -removeIslands -decimateMesh 200000
Killed
File “/code/run.py”, line 68, in
app.execute()
File “/code/stages/odm_app.py”, line 95, in execute
File “/code/opendm/types.py”, line 356, in run
[Previous line repeated 2 more times]
File “/code/opendm/types.py”, line 337, in run
File “/code/stages/odm_meshing.py”, line 75, in process
smooth_dsm=not args.fast_orthophoto)
File “/code/opendm/mesh.py”, line 46, in create_25dmesh
verbose=verbose)
File “/code/opendm/mesh.py”, line 183, in screened_poisson_reconstruction
'-decimateMesh {max_vertex} {verbose} '.format(**cleanupArgs))
Exception: Child returned 137
import imp
