Good morning all,
until then all my spots were taken into account, yesterday I launched a new spot and 4 times I had:
process completed with code 1
I had already read on the forum where the concern came from, but I did everything right and I do not understand.
only 26 pictures !
Docker is open, I have update in terminal and nothing
thank you
Laurent
i have that
docker run -d -p 80:80 docker/getting-started
docker: Error response from daemon: dial unix docker.raw.sock: connect: connection refused.
my internet connection works !
thank you
Laurent
Note that I have a 3GHZ mac with 64 GB of ram, so I donât think it comes from the computer.
I will try to link to the 26 photos
hello,
good evening, I made a dropbox link, but it doesnât work to show you the pictures âŚ
I reduced the size considerably, I tried it on WEBODM and itâs the same, it doesnât work, it must come from the photos because I did another test with other photos and it works
How to create another link please
warning warning !
to review the file it is 360 ° and I do not know webodm take that into account. so if you donât, donât bother straining your brain. if webodm takes it, then there is a problem. Many thanks to you and have a nice evening
Laurent
Have you set your lens type to spherical when you process it in WebODM?
Good evening,
No I stayed on default settings
Thank you for your reply
Laurent
Give it another run with the spherical camera model to see if it behaves better, maybe.
That is to say ?
Do another test with the phantom SDK?
Thank you and good day
Laurent
Hello again,
Indeed, it works in sphere mode but the rendering is really ârubbishâ Thanks to you
Iâm just starting out, Iâm experimenting, so sorry!
Hey, thatâs an internal address. We canât access it from outside your network.
Can you post that example elsewhere?
system
Closed
11 December 2020 16:15
#16
