Problems with Windows installation process
odm
Hello all,
i did everything similar to the installation explanation:
https://docs.opendronemap.org/installation.html#installation
But get the error message which is attached (No containers to start):
Starting db … failed
Starting broker … failed
Starting worker … failed
Starting node-odm … failed
Starting webapp … failed
Creating network “odm-git_default” with the default driver
Pulling node-odm (opendronemap/nodeodm:)…
latest: Pulling from opendronemap/nodeodm
Do i have to start docker additionally (Docker Desktop is running). Can you help me please?
Thanks for your help!
Obi
Hi Obi,
No containers to start is a warning, not an error. 3 lines down where it says latest: Pulling from opendronemap/nodeodm it is downloading the containers you need. This can take a while, so do this on the fastest connection you can, and be patient.
Welcome to the community!
Good point, my internet connection is very slow. So i just wait some more time.
Thank you @smathermather-cm!
I am new to ODM, something similar is happening to me; in the end it seems “unauthorized: authentication required”
Can someone help me?WebODM
rather than use the docker-compose.yml … comomand I would download from github using gitgui then in gitbash run ./webodm.sh. This process is documented in step 4 in this https://docs.opendronemap.org/installation.html. It a pretty big download so will take a while
