Problems with the installation in ubuntu 19.10
Hello, I have changed my computer and now I cannot reinstall the WebODM.
I use Ubuntu 19.10 and I have followed the instructions of the “missing guide” which I bought.
I throw this error.
The worst part is that even if I process it in my WebODM Lightning account, I can’t see it in the application.
Thanks in advance for your help. Sorry for my bad english
[email protected]:~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
File “/usr/local/bin/docker-compose”, line 6, in
from compose.cli.main import main
File “/usr/local/lib/python2.7/dist-packages/compose/cli/main.py”, line 18, in
import docker
File “/usr/local/lib/python2.7/dist-packages/docker/init.py”, line 2, in
from .api import APIClient
File “/usr/local/lib/python2.7/dist-packages/docker/api/init.py”, line 2, in
from .client import APIClient
File “/usr/local/lib/python2.7/dist-packages/docker/api/client.py”, line 10, in
from .build import BuildApiMixin
File “/usr/local/lib/python2.7/dist-packages/docker/api/build.py”, line 6, in
from … import auth
File “/usr/local/lib/python2.7/dist-packages/docker/auth.py”, line 9, in
from .utils import config
File “/usr/local/lib/python2.7/dist-packages/docker/utils/init.py”, line 3, in
from .decorators import check_resource, minimum_version, update_headers
File “/usr/local/lib/python2.7/dist-packages/docker/utils/decorators.py”, line 4, in
from . import utils
File “/usr/local/lib/python2.7/dist-packages/docker/utils/utils.py”, line 13, in
from … import tls
File “/usr/local/lib/python2.7/dist-packages/docker/tls.py”, line 5, in
from .transport import SSLHTTPAdapter
File “/usr/local/lib/python2.7/dist-packages/docker/transport/init.py”, line 3, in
from .ssladapter import SSLHTTPAdapter
File “/usr/local/lib/python2.7/dist-packages/docker/transport/ssladapter.py”, line 23, in
from backports.ssl_match_hostname import match_hostname
ImportError: No module named ssl_match_hostname
import docker
from … import auth
from . import utils
from … import tls
