OK., thanks for suggestions. I ran orthophoto in default, like I said, unfortunately this time WebODM returned an error. I do not understand what is the source of this problem as I ran it before with no errors. But I cannot swear that it was the default setting too.
Console
90
Input file size is 3603, 5774
0...10...20...30...40...50...60...70...80...90...100 - done.
[INFO] running gdalbuildvrt -resolution highest -r bilinear "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/merged.vrt" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/tiles.small_filled.tif" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/tiles.tmp.tif"
[INFO] running gdal_translate -co NUM_THREADS=1 -co TILED=YES -co BIGTIFF=IF_SAFER -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 47.55% "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/merged.vrt" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/tiles.tif"
[INFO] Starting smoothing...
[INFO] Smoothing iteration 1
[INFO] Completed smoothing to create /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/mesh_dsm.tif in 0:00:11.402316
[INFO] Completed mesh_dsm.tif in 0:00:18.714972
[INFO] Creating mesh from DSM: /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/mesh_dsm.tif
[INFO] running "/code/SuperBuild/install/bin/dem2mesh" -inputFile "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/tmp/mesh_dsm.tif" -outputFile "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.dirty.ply" -maxTileLength 2000 -maxVertexCount 200000 -maxConcurrency 1
[INFO] running "/code/SuperBuild/install/bin/OpenMVS/ReconstructMesh" -i "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.dirty.ply" -o "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.ply" --remove-spikes 0 --remove-spurious 0 --smooth 0 --target-face-num 400000 -v 0
03:53:48 [App ] Build date: Jan 15 2022, 01:48:36
03:53:48 [App ] CPU: AMD Ryzen 5 2600 Six-Core Processor (1 cores)
03:53:48 [App ] RAM: 96.84GB Physical Memory 2.00GB Virtual Memory
03:53:48 [App ] OS: Linux 5.11.0-46-generic (x86_64)
03:53:48 [App ] SSE & AVX compatible CPU & OS detected
03:53:48 [App ] Command line: -i /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.dirty.ply -o /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.ply --remove-spikes 0 --remove-spurious 0 --smooth 0 --target-face-num 400000 -v 0
Decimated faces 45165 (7.68%, 773ms, ETA 9s)...
Decimated faces 66784 (11.35%, 891ms, ETA 6s)...
Decimated faces 81163 (13.80%, 1s, ETA 6s)...
Decimated faces 103678 (17.63%, 1s, ETA 5s)...
Decimated faces 125235 (21.29%, 1s, ETA 4s)...
Decimated faces 147269 (25.04%, 1s, ETA 4s)...
Decimated faces 169299 (28.78%, 1s, ETA 3s)...
Decimated faces 190733 (32.42%, 1s, ETA 3s)...
Decimated faces 211539 (35.96%, 1s, ETA 3s)...
Decimated faces 229731 (39.05%, 1s, ETA 2s)...
Decimated faces 249258 (42.37%, 2s, ETA 2s)...
Decimated faces 267553 (45.48%, 2s, ETA 2s)...
Decimated faces 285136 (48.47%, 2s, ETA 2s)...
Decimated faces 303601 (51.61%, 2s, ETA 2s)...
Decimated faces 321537 (54.66%, 2s, ETA 2s)...
Decimated faces 339030 (57.64%, 2s, ETA 2s)...
Decimated faces 356273 (60.57%, 2s, ETA 1s)...
Decimated faces 373186 (63.44%, 2s, ETA 1s)...
Decimated faces 389223 (66.17%, 3s, ETA 1s)...
Decimated faces 405158 (68.88%, 3s, ETA 1s)...
Decimated faces 421233 (71.61%, 3s, ETA 1s)...
Decimated faces 437659 (74.40%, 3s, ETA 1s)...
Decimated faces 453854 (77.16%, 3s, ETA 1s)...
Decimated faces 469871 (79.88%, 3s, ETA 933ms)...
Decimated faces 485503 (82.54%, 3s, ETA 808ms)...
Decimated faces 500380 (85.07%, 3s, ETA 691ms)...
Decimated faces 514336 (87.44%, 4s, ETA 583ms)...
Decimated faces 528575 (89.86%, 4s, ETA 472ms)...
Decimated faces 542750 (92.27%, 4s, ETA 360ms)...
Decimated faces 556529 (94.61%, 4s, ETA 255ms)...
Decimated faces 570464 (96.98%, 4s, ETA 143ms)...
Decimated faces 584237 (99.32%, 4s, ETA 32ms)...
Decimated faces 588229 (100%, 4s759ms)
03:53:56 [App ] MEMORYINFO: {
03:53:56 [App ] VmPeak: 350232 kB
03:53:56 [App ] VmSize: 147520 kB
03:53:56 [App ] } ENDINFO
[INFO] Finished odm_meshing stage
[INFO] Running mvs_texturing stage
[INFO] Writing MVS Textured file in: /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_texturing/odm_textured_model_geo.obj
[INFO] running "/code/SuperBuild/install/bin/texrecon" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/opensfm/undistorted/reconstruction.nvm" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_mesh.ply" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_texturing/odm_textured_model_geo" -d gmi -o gauss_clamping -t none --no_intermediate_results --max_texture_size=8192
/code/SuperBuild/install/bin/texrecon (built on Jan 15 2022, 01:47:53)
Load and prepare mesh:
Reading PLY: 171231 verts... 342596 faces... done.
Generating texture views:
NVM: Loading file...
NVM: Number of features: 287371
Loading 100%... done. (Took 133.908s)
Building adjacency graph:
Adding edges 100%... done. (Took 0.525s)
513838 total edges.
View selection:
Building BVH from 342596 faces... done. (Took: 666 ms)
Calculating face qualities 100%... done. (Took 305.913s)
Postprocessing face infos 100%... done. (Took 2.124s)
Maximum quality of a face within an image: 165333
Clamping qualities to 1273.19 within normalization.
Optimizing:
Time[s] Energy
0 360632
8 358482
9 353996
9 351639
10 350444
11 349840
12 349397
15 349204
16 348993
17 348849
17 348750
18 348681
18 348603
19 348542
131693 faces have not been seen
Took: 329.082s
Generating texture patches:
Running... done. (Took 128.402s)
6438 texture patches.
Running global seam leveling:
Create matrices for optimization... done.
Lhs dimensionality: 140494 x 140494
Calculating adjustments:
Color channel 0: CG took 100 iterations. Residual is 9.27642e-05
Color channel 1: CG took 100 iterations. Residual is 8.83614e-05
Color channel 2: CG took 100 iterations. Residual is 9.53038e-05
Took 0.786 seconds
Adjusting texture patches 100%... done. (Took 23.732s)
Running local seam leveling:
Blending texture patches 100%... done. (Took 277.664s)
Generating texture atlases:
Sorting texture patches... done.
Working on atlas 40 100%... done.
Finalizing texture atlases... done. (Took: 0s)
Building objmodel:
Saving model... done.
Whole texturing procedure took: 1112.85s
[INFO] Writing MVS Textured file in: /var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_texturing_25d/odm_textured_model_geo.obj
[INFO] running "/code/SuperBuild/install/bin/texrecon" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/opensfm/undistorted/reconstruction.nvm" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_meshing/odm_25dmesh.ply" "/var/www/data/65255377-2a79-45f1-be54-422cf72c306b/odm_texturing_25d/odm_textured_model_geo" -d gmi -o gauss_clamping -t none --no_intermediate_results --nadir_mode --max_texture_size=8192
Reading PLY: 200208 verts... 399839 faces... done.
Loading 100%... done. (Took 134.796s)
Adding edges 100%... done. (Took 0.615s)
599473 total edges.
View selection:
Building BVH from 399839 faces... done. (Took: 884 ms)
Calculating face qualities 100%... done. (Took 309.595s)
Postprocessing face infos 100%... done. (Took 7.963s)
Maximum quality of a face within an image: 0.999726
Clamping qualities to 0.981929 within normalization.
Optimizing:
Time[s] Energy
1 107297
6 104730
7 99285
9 96562
10 95259
12 94523
13 94085
16 93856
17 93591
18 93426
20 93314
21 93218
22 93152
24 93114
25 93094
26 93072
27 93051
16192 faces have not been seen
Took: 347.78s
Running... done. (Took 135.087s)
7109 texture patches.
Lhs dimensionality: 220828 x 220828
Color channel 0: CG took 96 iterations. Residual is 9.85506e-05
Color channel 1: CG took 100 iterations. Residual is 9.21131e-05
Color channel 2: CG took 99 iterations. Residual is 9.8651e-05
Took 1.206 seconds
Adjusting texture patches 100%... done. (Took 722.932s)
double free or corruption (out)
Aborted (core dumped)
Child returned 134
File "/code/opendm/types.py", line 346, in run
[Previous line repeated 4 more times]
File "/code/opendm/types.py", line 327, in run
File "/code/stages/mvstex.py", line 117, in process
system.run('"{bin}" "{nvm_file}" "{model}" "{out_dir}" '
opendm.system.SubprocessException: Child returned 134
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying/
100 - done.
Apart of few last rows, everything before looks ok. Strange. Full console output is under whole area / WebODM / setting 1 folder.
So I will try whole area orthophoto again, this time setting 4 and use-fixed-camera-params false.
Regarding rolling shutter setting in WebODM I found this: use-fixed-camera-params — OpenDroneMap 2.7.1 documentation
it really suggests to use it to help with the rolling shutter. I would suggest to extend the note for users, if we should not use this setting. And I do not agree to renaming my original post topic as I think it is not so simple regarding distortion and failure in getting reasonable quality orthophoto. I suppose we will se it after setting 4 without use-fixed-camera-params is finished.
