Just want to report the issues.
Compile and build latest WebODM and ODM and I got following errors:
Data set is Brighton beach. Processing is finished fine without errors
Contours plugin fail with error no mater what settings I am putting :
“Invalid GeoJSON object.”
Elevation Map plugin fail with error:
Could not execute GRASS script /webodm/plugins/elevationmap/elevationmap.py from /webodm/app/media/tmp/tmpzhs0yn_6_grass_engine: Starting GRASS GIS… Creating new GRASS GIS location … Executing <python /webodm/plugins/elevationmap/elevationmap.py interval=1 epsg=4326 noise_filter_size=3.0 format=GeoJSON dsm=/webodm/app/media/project/1/task/d8315a8f-2e33-4231-b05b-289f5dfec884/assets/odm_dem/dsm.tif> … Traceback (most recent call last): File “/webodm/plugins/elevationmap/elevationmap.py”, line 235, in sys.exit(main()) File “/webodm/plugins/elevationmap/elevationmap.py”, line 76, in main kernel = get_kernel(float(opts[‘noise_filter_size’]), dsm) File “/webodm/plugins/elevationmap/elevationmap.py”, line 137, in get_kernel return cv2.getStructuringElement(cv2.MORPH_ELLIPSE, (round(noise_filter_size / dsm.res[0]), round(noise_filter_size / dsm.res[1]))) TypeError: integer argument expected, got float Execution of <python /webodm/plugins/elevationmap/elevationmap.py interval=1 epsg=4326 noise_filter_size=3.0 format=GeoJSON dsm=/webodm/app/media/project/1/task/d8315a8f-2e33-4231-b05b-289f5dfec884/assets/odm_dem/dsm.tif> finished. Cleaning up temporary files…
… but when i set Noise filter to (Do not filter noise 0 meter) it works fine.
or
when change in elevationmap.py
line 137
to
cv2.getStructuringElement(cv2.MORPH_ELLIPSE, (int(round(noise_filter_size / dsm.res[0])), int(round(noise_filter_size / dsm.res[1]))))
works fine with Noise filter param
Mm, could be a bug. Would you be interested in opening a pull request?
Will do for elevation , but for contours don’t know what has to be done.
@rumenchooo @pierotofy has there been any update on this, I am getting the exact same errors and want to know if there is a fix for it.
I haven’t had the time to troubleshoot this
@pierotofy when a solution is found and its fixed could you let me know. Thanks for all your hard work. Love using ODM.
Hey everyone!
Just as an FYI, I just proposed rumenchooo’s changes to the elevation map plugin.
https://github.com/OpenDroneMap/WebODM/pull/861
@pierotofy I wanted to check in on the contours to see if the issue has been fixed?
I have the same issue, I’m getting the following error:
ERROR Could not execute GRASS script /webodm/plugins/contours/calc_contours.py from /webodm/app/media/tmp/tmpptpipu27_grass_engine: Starting GRASS GIS...
Creating new GRASS GIS location <location>...
Executing <python /webodm/plugins/contours/calc_contours.py dem_file=/webodm/app/media/project/12/task/d7b470f3-e3d4-404a-863d-8f5f3477844e/assets/odm_dem/dsm.tif simplify=0.2 format=GeoJSON epsg=4326 interval=1.0> ...
File "/webodm/plugins/contours/calc_contours.py", line 92, in <module>
sys.exit(main())
File "/webodm/plugins/contours/calc_contours.py", line 52, in main
if opts['format'] == "GeoJSON":
KeyError: 'format'
Execution of <python /webodm/plugins/contours/calc_contours.py dem_file=/webodm/app/media/project/12/task/d7b470f3-e3d4-404a-863d-8f5f3477844e/assets/odm_dem/dsm.tif simplify=0.2 format=GeoJSON epsg=4326 interval=1.0> finished.
Cleaning up temporary files...
[2020-07-08 21:27:43,723: ERROR/ForkPoolWorker-1] worker.tasks.execute_grass_script[a786f14a-77dd-4221-8e94-aebe3a79600e]: Could not execute GRASS script /webodm/plugins/contours/calc_contours.py from /webodm/app/media/tmp/tmpptpipu27_grass_engine: Starting GRASS GIS...
sys.exit(main())
KeyError: 'format'
Did you manage to make it work?
Triple check that you are running the correct version of GRASS.
[email protected]:/webodm# grass --version
GRASS GIS 7.8.3
