Hey, i’ve been trying to process this MicaSense RedEdge MX sample data using WebODM over the last few days.
The first problem I’ve run into is that ODM doesn’t seem to support 10 bands data as of now. So I had to remove some bands from the data to get it to work. It seems that it works just fine with 9 bands, but as ODM adds an own alpha band to the final orthophoto you are only able to process 8 own bands.
My questions regarding this are:
- Are there any plans for 10 bands support in the future?
- Is there a way I can prevent ODM from creating/adding the alpha band to the final orthophoto?
Removing 2 bands from the sample data and processing 8 bands using the default ‘multispectral’ settings worked pretty good though. But when looking at the final orthophoto I noticed some problems in the image.
There are a lot of those “stiches” or “seams” in the orthophoto.
- What could cause those “seams” effects? Is that a problem with the bands alignment?
- Is there a way I could get rid of those effects (by using some setting parameter)?
Thanks in advance,
John
