Problems installing WebODM on new install of Ubuntu 22.04
I’ve followed the Linux installation directions for WebODM but they appear to be outdated.
  1. sudo apt update
  2. curl …
    curl was not already installed so I did a manual install
  3. sh get-docker.sh
  4. sudo apt install -y git python python-pip
    This command did not install pip.
    so I manually installed pip
  5. docker-compose was not installed so I had to install it.
    it reports a build version of “unknown”
  6. git clone worked
  7. cd WebODM worked
  8. ./wedodm.sh start -------------- this crashed
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
Postgres DB directory: dbdata
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.10/http/client.py”, line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.10/http/client.py”, line 1037, in _send_output
self.send(msg)
File “/usr/lib/python3.10/http/client.py”, line 975, in send
self.connect()
File “/usr/lib/python3/dist-packages/docker/transport/unixconn.py”, line 30, in connect
sock.connect(self.unix_socket)
PermissionError: [Errno 13] Permission denied
with more pages as well.
Suggestions? thanks
If I remember correctly there should a bit about adding your user to the docker group.
sudo usermod -aG docker $USER
so i added my user name and tried it again but got the same exact error messages.
I tried $./wedodm.sh update and that spewed lots of errors as well.
I just read in another thread that I have to start webodm as sudo
sudo ./webodm.sh start
You do not, if you are in the Docker group (and in general running things as root is not a great thing).
Group membership changes are only reflected after login or reboot, so do that if you have not yet.
