Hello all…
I have this problem after updating. I have tried different browsers.
Mattias,
Can you tell us the browser(s), platform, and version of WebODM?
I briefly experieced the same with the Docker version, but subsequent updates have resolved that behavior.
Sorry…
Ubuntu server install, tried chrome and firefox. Webodm 1.9.11
And you’ve done the webodm.sh update step to ensure that you’re fully up to date?
Correct
Are your projects backed up?
If so, you could uninstall/reinstall WebODM in Docker.
Alternatively, you could try using the Administration panel to remove the Projects/Tasks and see if you can re-add new Projects/Tasks and have it behave properly.
If not, I think a full remove/reinstall would be an option.
Open the Chrome developer Console (F12) and see if you get any errors when you trigger the crash?
main-6bf8410ab6d65132987b.js:22 TypeError: Cannot read properties of undefined (reading ‘length’)
at eval (TaskView.js:67)
at n.value (TaskView.js:67)
at Da (main-6bf8410ab6d65132987b.js:22)
at Za (main-6bf8410ab6d65132987b.js:22)
at gs (main-6bf8410ab6d65132987b.js:22)
at gl (main-6bf8410ab6d65132987b.js:22)
at _l (main-6bf8410ab6d65132987b.js:22)
at ll (main-6bf8410ab6d65132987b.js:22)
at main-6bf8410ab6d65132987b.js:22
at e.unstable_runWithPriority (main-6bf8410ab6d65132987b.js:30)
Mm, looks like the webpack build did not go correctly when you updated. Try to rebuild and check for any error messages during the update/build commands.
