After running the --media-dir /new/path I am getting some error.
The --media-dir command does not change the location of the task output. I am able to run webodm and the task complete but I guess to the default location.
I have tried ./webodm.sh rebuild and then start up again but this error keeps coming.
What could be the problem?
worker | [2021-01-13 14:18:37,291: ERROR/ForkPoolWorker-1] worker.tasks.process_task[0319b8ee-d7ff-4e6c-a621-4d6060769f4e]: Uncaught error! This is potentially bad. Please report it to http://github.com/OpenDroneMap/WebODM/issues: [Errno 2] No such file or directory: ‘/webodm/app/media/project/9/task/e744a8d8-3686-45ac-a800-32168d3c544e/’ Traceback (most recent call last):
worker | File “/webodm/worker/tasks.py”, line 109, in process_task
worker | task.process()
worker | File “/webodm/app/models/task.py”, line 440, in process
worker | resized_images = self.resize_images()
worker | File “/webodm/app/models/task.py”, line 871, in resize_images
worker | images_path = self.find_all_files_matching(r’.*.(jpe?g|tiff?)$')
worker | File “/webodm/app/models/task.py”, line 851, in find_all_files_matching
worker | return [os.path.join(directory, f) for f in os.listdir(directory) if
worker | FileNotFoundError: [Errno 2] No such file or directory: ‘/webodm/app/media/project/9/task/e744a8d8-3686-45ac-a800-32168d3c544e/’
./webodm.sh down
./wedodm.sh rebuild
./webodm. start
and got this now instead
Attaching to webodm_node-odm_1, broker, db, worker, webapp
db |
db | PostgreSQL Database directory appears to contain a database; Skipping initialization
db |
db | LOG: database system was shut down at 2021-01-14 08:41:59 UTC
broker | 1:C 14 Jan 2021 08:42:32.416 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
broker | 1:C 14 Jan 2021 08:42:32.417 # Redis version=6.0.10, bits=64, commit=00000000, modified=0, pid=1, just started
broker | 1:C 14 Jan 2021 08:42:32.417 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
db | LOG: MultiXact member wraparound protections are now enabled
broker | 1:M 14 Jan 2021 08:42:32.418 * Running mode=standalone, port=6379.
broker | 1:M 14 Jan 2021 08:42:32.418 # Server initialized
broker | 1:M 14 Jan 2021 08:42:32.418 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add ‘vm.overcommit_memory = 1’ to /etc/sysctl.conf and then reboot or run the command ‘sysctl vm.overcommit_memory=1’ for this to take effect.
node-odm_1 | info: Authentication using NoTokenRequired
db | LOG: database system is ready to accept connections
worker | Password for user postgres:
db | LOG: autovacuum launcher started
broker | 1:M 14 Jan 2021 08:42:32.419 * Ready to accept connections
node-odm_1 | info: Listening on 0.0.0.0:6367 UDP for progress updates
worker | psql: fe_sendauth: no password supplied
node-odm_1 | info: No tasks dump found
worker | Postgres is unavailable - sleeping
node-odm_1 | info: Checking for orphaned directories to be removed…
node-odm_1 | info: Server has started on port 3000
webapp | Password for user postgres:
webapp | psql: fe_sendauth: no password supplied
webapp | Postgres is unavailable - sleeping
Note! These values might be relative to the virtualization environment in which the application is running, not necessarily the values of the your machine. See instructions for Windows and MacOS for changing these values in a Docker setup.
So to change the storage space I need to change the docker-compose.yml file?
The diagram from the diagnostic panel will show you the free disk space available on the container (not the app/media directory). I wouldn’t rely on it if you’re mounting volumes
Theoretically you shouldn’t need to modify the docker-compose files, that’s what the --media-dir option does (it sets the WO_MEDIA_DIR variable).
