Soy Jośe Villa de México, saludos colegas:
Quisiera preguntarles sobre un problema con la instalación de WebODM en Windows 10 pro, seguí los pasos de la instalación en el orden indicado en “https://github.com/OpenDroneMap/WebODM”, es decir:
1.- instalé git
2.- instalé pyhton
3.- instalé docker para Windows
4.- Cloné el repositorio
4.- Le di la instrucción ./webodm.sh start y el resultado es el que pongo al final.
¿Podrian orientarme?
Cordialmente
Jośe Villa
Jose Luis@CARTOGRAFIA MINGW64 /c/WebODM (master)$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
[13292] Failed to execute script docker-compose
File “site-packages\docker\api\client.py”, line 205, in _retrieve_server_version
File “site-packages\docker\api\daemon.py”, line 181, in version
File “site-packages\docker\utils\decorators.py”, line 46, in inner
File “site-packages\docker\api\client.py”, line 228, in _get
File “site-packages\requests\sessions.py”, line 543, in get
File “site-packages\requests\sessions.py”, line 530, in request
File “site-packages\requests\sessions.py”, line 643, in send
File “site-packages\requests\adapters.py”, line 449, in send
File “site-packages\urllib3\connectionpool.py”, line 677, in urlopen
File “site-packages\urllib3\connectionpool.py”, line 392, in _make_request
File “http\client.py”, line 1244, in request
File “http\client.py”, line 1290, in _send_request
File “http\client.py”, line 1239, in endheaders
File “http\client.py”, line 1026, in _send_output
File “http\client.py”, line 966, in send
File “site-packages\docker\transport\npipeconn.py”, line 32, in connect
File “site-packages\docker\transport\npipesocket.py”, line 23, in wrapped
File “site-packages\docker\transport\npipesocket.py”, line 72, in connect
File “site-packages\docker\transport\npipesocket.py”, line 59, in connect
pywintypes.error: (5, ‘CreateFile’, ‘Acceso denegado.’)
File “docker-compose”, line 3, in
File “compose\cli\main.py”, line 67, in main
File “compose\cli\main.py”, line 123, in perform_command
File “compose\cli\command.py”, line 69, in project_from_options
File “compose\cli\command.py”, line 132, in get_project
File “compose\cli\docker_client.py”, line 43, in get_client
File “compose\cli\docker_client.py”, line 170, in docker_client
File “site-packages\docker\api\client.py”, line 188, in init
File “site-packages\docker\api\client.py”, line 213, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: (5, ‘CreateFile’, ‘Acceso denegado.’)
[13012] Failed to execute script docker-compose
