I was refered to the community from the github problem page.
How did you install OpenDroneMap? (Docker, natively, …)?
installed via Docker
What’s your browser and operating system?
Chrome 83 on Windows 10
What is the problem?
it appears I can’t conect to the server
What should be the expected behavior? If this is a feature request, please describe in detail the changes you think should be made to the code, citing files and lines where changes should be made, if possible.
I can’t run ODM because of it
How can we reproduce this? (What steps did you do to trigger the problem? What parameters are you using for processing? If possible please include a copy of your dataset uploaded on Google Drive or Dropbox. Be detailed)
Do other people have trouble with connecting to the server?
