Prescription map
Hi all,
I need an information. Once obtained Index for health Plants, is there a way to obtain prescription maps, as consequence of the obtained maps?
Thanks a lot.
You’re going to need to make the prescription maps yourself.
There are many tools and procedures for this.
You could start by doing a reclassification by Index value, and setting a prescription value per reclassified Index range.
Do you have an agronomist to work with to make the proper prescription?
Thanks a lot @Saijin_Naib.
I would like to have, starting from the index map, the possibility to obtain a prescription map defining the number of zone I would have and definining , later, for each zone the relative amount for the prescription.
I think that the agronomist could intervene just in the final step, defining the amount for the prescription.
At the beginning I need the possibility to make the different zones starting from index map.
For example, starting from index map:
I would like to obtain a similar one:
Obviously I would like to develop such feature in webODM. Do you know if any API or tools could be used for such purpose?
Thanks a lot for your time.
Could you please suggest me what tool could be suitable for my purpose? Thanks a lot!
This seems similar to the elevation plugin in WebODM (except for plant health instead of elevation). I’m sure it could be modified to generate prescription maps…
thanks a lot @pierotofy , so you suggest to start from the implementation of the elevation plugin?
Thanks a lot!!!
Do you think it could be the best way for my purposes?
Yes.
any updates about this plugin?
