precision pointcloud
Hello every one !!
I process a point cloud using WebOdm, the Drone is a Autel Evo II Pro 6K , i coordinate 8 GCP with my GNSS , and the problem is when i check the elevation of some points (GCP) the error was not constant and at some points 0,30 meters . then i process with Agisoft Metashape and the points have 0,05 meters ,.
What is the problem with ODM.
Are you able to share your data and processing parameters?
