Introduction myself - From long time I folloe this group and read and to it’s my first question. Thanks
Using WebDOM I loook the way to be able to specify my favorites multispectral indexes and not proceed all. Ex: NDVI + VARI
How is possible ?
How is possible ?
Welcome, Orca!
Are you asking if you can customize the list of indices so that only a few show up for people using your copy of WebODM?
What type of images are you using?
There’s a lot you can do in QGis with images to make NDVI and others.
Hi Saijin_Naib,
Before start the processing I want to be able to proceed only NDVI and VARI. I don’t need others indexes. It’s possible to define into the Customize modal window which indexes to proceed only ? It’s like when I put a GeoJSON to limit the process to a boundary but not I want to specify indexes.
The result from the processed map will show only under Plant Healt "Algorithm " NDVI and VARI indexes.
Hope you understand.
I come from Pix4DFields where the process is :
My images are from Micasense Altum
Orca,
The other indices aren’t generated during processing. They’re calculated on the fly when you choose them from the drop-down.
Saijin_Naib, that’s why I never for the answers when I searching for that
Question 2 : From your answer, it’s possible in this way to limit to an user to see only few Algorithm available to generate on the fly ? My use case is when I share a map to an user, I want to allow only NDVI and VARI to be generated on the fly.
Yes, you’d have to modify some of the source files for you instance of WebODM:
Thank you for your informatioms, very appreciate.
