Point cloud classification how to?
Hi I tried to use the point cloud classification but it seems like its not doing it these are my settings is there anything else I need to change?
FO]    Initializing ODM 2.7.1 - Sat Jan 22 16:41:43  2022
[INFO]    ==============
[INFO]    auto_boundary: True
[INFO]    boundary: {}
[INFO]    build_overviews: False
[INFO]    camera_lens: auto
[INFO]    cameras: {}
[INFO]    cog: True
[INFO]    copy_to: None
[INFO]    crop: 3
[INFO]    debug: True
[INFO]    dem_decimation: 1
[INFO]    dem_euclidean_map: False
[INFO]    dem_gapfill_steps: 3
[INFO]    dem_resolution: 5
[INFO]    depthmap_resolution: 640
[INFO]    dsm: True
[INFO]    dtm: True
[INFO]    end_with: odm_postprocess
[INFO]    fast_orthophoto: False
[INFO]    feature_quality: ultra
[INFO]    feature_type: sift
[INFO]    force_gps: False
[INFO]    gcp: None
[INFO]    geo: None
[INFO]    gps_accuracy: 10
[INFO]    ignore_gsd: True
[INFO]    matcher_neighbors: 16
[INFO]    matcher_type: flann
[INFO]    max_concurrency: 16
[INFO]    merge: all
[INFO]    mesh_octree_depth: 12
[INFO]    mesh_size: 400000
[INFO]    min_num_features: 20000
[INFO]    name: 7a335c76-ec07-4ca1-a1ad-c2264f2e63e6
[INFO]    optimize_disk_space: False
[INFO]    orthophoto_compression: DEFLATE
[INFO]    orthophoto_cutline: False
[INFO]    orthophoto_kmz: False
[INFO]    orthophoto_no_tiled: False
[INFO]    orthophoto_png: False
[INFO]    orthophoto_resolution: 0.6
[INFO]    pc_classify: True
[INFO]    pc_csv: False
[INFO]    pc_ept: True
[INFO]    pc_filter: 2.5
[INFO]    pc_geometric: True
[INFO]    pc_las: False
[INFO]    pc_quality: ultra
[INFO]    pc_rectify: False
[INFO]    pc_sample: 0
[INFO]    pc_tile: False
[INFO]    primary_band: auto
[INFO]    project_path: /var/www/data
[INFO]    radiometric_calibration: none
[INFO]    rerun: None
[INFO]    rerun_all: False
[INFO]    rerun_from: ['dataset', 'split', 'merge', 'opensfm', 'openmvs', 'odm_filterpoints', 'odm_meshing', 'mvs_texturing', 'odm_georeferencing', 'odm_dem', 'odm_orthophoto', 'odm_report', 'odm_postprocess']
[INFO]    resize_to: -1
[INFO]    sfm_algorithm: incremental
[INFO]    skip_3dmodel: False
[INFO]    skip_band_alignment: False
[INFO]    skip_orthophoto: True
[INFO]    skip_report: True
[INFO]    sm_cluster: None
[INFO]    smrf_scalar: 1.25
[INFO]    smrf_slope: 0.15
[INFO]    smrf_threshold: 0.5
[INFO]    smrf_window: 18.0
[INFO]    split: 999999
[INFO]    split_image_groups: None
[INFO]    split_overlap: 150
[INFO]    texturing_data_term: gmi
[INFO]    texturing_keep_unseen_faces: False
[INFO]    texturing_outlier_removal_type: gauss_clamping
[INFO]    texturing_skip_global_seam_leveling: False
[INFO]    texturing_skip_local_seam_leveling: False
[INFO]    texturing_tone_mapping: none
[INFO]    tiles: False
[INFO]    time: False
[INFO]    use_3dmesh: False
[INFO]    use_exif: False
[INFO]    use_fixed_camera_params: False
[INFO]    use_hybrid_bundle_adjustment: False
[INFO]    verbose: True
What do you want it to do?
Well on the viewer it shows you can view buildings, vegetation, water, ground etc
so some of that if possible.
It tries to separate buildings/stuff from the ground.
I find CloudCompare to be better at that and it’s also very good for sampling down the point count.
To classify land I thing it’s easier to do a supervised classification in QGis of the raster.
You’ll need to tune the smrf variables to change how sensitive it is to classificaiton. Right now, you’ll mostly get ground/unclassified.
https://docs.opendronemap.org/arguments/
