--pmvs-min-images and --force-focal flags
I have been told that in the past (at least), I needed to use --pmvs-min-images 2 so that ODM uses features found in 2 images. This is because I have poor overlap. I am using historical areal photography. Does this flag still exist? I am also looking for --force-focal. Images are taken with a 152.4mm focal.
Thanks for your help.
Nicolas
We do not expose these options, unfortunately.
You might have to manually edit the OpenSFM config on disk.
Could Focal information be taken from EXIF info (FocalLength parameter) ?
Normally it would be, but I believe these data do not have much, if anything, by way of metadata given they’re old scans of film.
But you can calculate some values, I have some historical images but I cannot follow this procedure since I have no the coordinates like there but I have gcp_list.txt file with spatial and images coordinates.
I try to run ODM but it failed after that I realize my tif has no EXIF at all. So I could add some parameters like fixed focal lenght, images dimension and others but I don’t know if this could help.
If they are read by ODM, which are really needed?
If you’re going to be adding geoinformation to files that don’t have it, the geo.txt file is the proper way to do so, not the gcp_list.txt file.
https://docs.opendronemap.org/geo/
What information do you have that you could possibly add to the EXIF and/or the geo.txt file?
If you have an Idea what the Lense was, you could try to get the same pictures of this Areal with a Mavic 2 zoom (adjustable lense). Than you could get an idea of the correct gps. (For sure with gps offset but I guess better than just trying to guess)
Indeed,
All I had was the flight altitude(20,000 feet), the focal-Length (152.4mm) and the film size (9x9inch)
Nicolas
Yes,
Start with the geo.txt file. You can use the gcp_list.txt to georeference the files. Use a Helmert transformation. Then use the scene centre and the angle of the scene (kappa), to make the geo.txt file. If you are successful, then try to refine with the gcp_list.txt file.
Nicolas
That could be complicated with a landscape that no longer exists and a flight altitude of 20,000 feet! I guess that could work in other situations.
Nicolas
Same here, but I have also some GCP taken few years ago with GPS finding some places on the old images
Thanks Nicolas,
could you explain a little bit better how to create create the geo.txt from the gcp_list.txt? I understood you suggest to apply a trasformation, how?
thank a lot
