Please tell me the solution, an error occurred in WebODM Manager and it became inoperable
The following error is displayed when WebODM Manager is executed.
Server: Docker Engine - Community
Engine:
Version: 18.09.1
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 4c52b90
Built: Wed Jan 9 19:41:49 2019
OS/Arch: linux/amd64
Experimental: false
Press Start WebODM to launch
Checking for MS Edge Zone…
Zones are OK
C:\WebODM Manager>cd WebODM/
C:\WebODM Manager\WebODM>docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting node-odm-1 …
Starting db …
Starting broker …
Starting worker …
Starting webapp …
e[3Ae[2K
Starting broker … e[32mdonee[0m
e[3Be[4Ae[2K
Starting db … e[31merrore[0m
e[4Be[2Ae[2K
Starting worker … e[31merrore[0m
e[2Be[1Ae[2K
Starting webapp … e[31merrore[0m
e[1Be[5Ae[2K
Starting node-odm-1 … e[31merrore[0m
e[5B
ERROR: for db Cannot start service db: driver failed programming external connectivity on endpoint db (729be4f956f1ddf055afe29a4ec305b5ae5cdeca392e9d4bb1c017c960719903): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:32948:tcp:172.24.0.4:5432: input/output error
C:\WebODM Manager\WebODM>exit 0
ERROR: for node-odm-1 Cannot start service node-odm-1: driver failed programming external connectivity on endpoint node-odm-1 (265ea58e06d1cdd28a7fc78235b3d70cbd4345bf1a75ca9eaaa3727c1c06d443): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:32949:tcp:172.24.0.2:3000: input/output error
If you cannot access WebODM within 5 minutes, press Update. You can close this window now.
And since an error message appeared on the screen, I update it but it does not work.
Please tell me how to resolve.
004
See if this post helps: https://github.com/docker/for-win/issues/573 ? Deactivate Experimental features, restart docker, then try again?
Currently, when restarting by right-clicking the Docker icon when starting Windows 10, it solved it.
Thank you very much.
