Pixel values when creating an orthomosaic from .tiff
Hello everyone,
I want to produce an orthomosaic of thermal images acquired with a zenmuse H20T.
I have pre-calibrated the images manually, so my base images are .tiff with pixel values in degrees celcius and metadata identical to the original RJPG.
With this data I am able to produce the orthomosaic with the correct values with Pix4D, as a proof of concept.
However with WebODM there are some problems.
For now my best results are obtained by giving ODM .tiff images (UINT 16bit) whose values have been extended between 0 and 65535 by adding 27315 to the temperature values.
Non-default parameters: auto-boundary: true, dsm: true, fast-orthophoto: true, radiometric-calibration: camera, skip-3dmodel: true
The orthomosaic creation works but the pixel values change completely. For example, while the base data varies between 27360 and 27700, the orthomosaic pixel values vary between -0.078 and 4.155.
I tested several other variations such as using .tiff SINT 16bit rescaled or non-scaled, radiometric-calibration: none, several ODM presets… however no configuration allowed me to obtain the original values. Some configurations even crash the creation process.
Here are the images in question (.tiff UINT 16bit rescalled): https://we.tl/t-hL4p0eo0fU
Here is the orthomosaic produced with the best results: https://we.tl/t-owUWlUcPrD
Has anyone ever faced a similar problem in creating orthomosaics?
Thanks!
Sorry for the trouble. Thank you for providing such great detail and sample data.
Are you able to provide the output from Pix4D, or at least the metadata/structure (band count, bit depth/type, etc)? It’d be helpful in starting to assess what’s happening.
Here is the orthomosaic produced with Pix4D, and the images used (SINT 16bit containing temperature data without recalling): https://we.tl/t-eOvtX7rlRA
On my side, when used with ODM, these images produce a 2 band raster (I don’t know what the 2nd band is) with the wrong values.
For UINT16 calibrated DJI H20T imagery, the ODM pipeline can translate the raw image values back to temperature values (in Float32 GeoTIFF) if you turn on the radiometric-calibration option. Since the raw data is single band, you should pass the skip-band-alignment option as well.
As H20T is not global shutter and the images are low resolution, you can also try the following options:
  • sfm-algorithm: planar (for flat areas)
  • fast-orthophoto: false
  • feature-quality: ultra
  • pc-quality: ultra
The radiometric calibration has indeed shown the best results so far (radiometric-calibration: camera) but the values are not the right ones.
I have tested on several types of images with the following parameters: auto-boundary: true, radiometric-calibration: camera, sfm-algorithm: planar, skip-3dmodel: true, skip-band-alignment: true
  • RJPEG: Orthomosaic creation ok but RGB values only.
  • TIFF UINT16 raw (=temp C) : Assembly fails
Logs
Child returned 134
File “/code/stages/odm_app.py”, line 88, in execute
File “/code/opendm/types.py”, line 380, in run
File “/code/opendm/types.py”, line 361, in run
File “/code/stages/run_opensfm.py”, line 35, in process
File “/code/opendm/osfm.py”, line 416, in feature_matching
self.match_features(rerun)
File “/code/opendm/osfm.py”, line 421, in match_features
self.run(‘match_features’)
File “/code/opendm/osfm.py”, line 34, in run
system.run(‘“%s” %s “%s”’ %
File “/code/opendm/system.py”, line 109, in run
opendm.system.SubprocessException: Child returned 134
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 3.1.7 documentation
  • TIFF UNIT16 scalled (=temp C + 27315) : Orthomosaic creation ok but pixel values are between 0 and 4.164
  • TIFF UNIT16 scalled (=tempC + 27315), but radiometric-calibration: none : Assembly fails
Logs
Child returned 1
File “/code/stages/openmvs.py”, line 226, in process
raise e
File “/code/stages/openmvs.py”, line 220, in process
system.run(‘“%s” %s’ % (context.omvs_densify_path, ’ '.join(config + gpu_config + extra_config)))
Do you have any clues about changing values in TIFF UNIT16 scalled? Or a way to allow the assembly not to fail?
