Pictures from video video (having a .srt file with gps location and altitude)
I own a DJI air2s drone which is not yet ready for automatic flight (harmony drone or dronelink for example on android) due to a manufacturer’s choice. In order to survey a terrain I have to take a hundred photos manually with the necessary overlays, and it also works in web odm. Now I would like to try to extract the photos automatically from a video with .srt subtitle files with gps position and altitude (example attached) to convert the video into photos with the corresponding data stored. I could use ffmpeg, to make the frames, and I’m not sure how to go about it: maybe I should transfer the data, coordinating the timing, from the .srt file to the exif data of a single photo. Has anyone tried this yet?
I’ve searched the forum and haven’t found anything similar.
extract from .srt file :
1
00:00:00,000 → 00:00:00,033
SrtCnt : 1, DiffTime : 33ms
2021-05-24 17:33:21,530,497
[iso : 100] [shutter : 1/350.0] [fnum : 280] [ev : 0] [ct : 5237] [color_md : default] [focal_len : 224] [dzoom_ratio: 10000, delta:0],[latitude: 37.037827] [longitude: 15.294875] [altitude: -4.800000]
2
00:00:00,033 → 00:00:00,066
SrtCnt : 2, DiffTime : 33ms
2021-05-24 17:33:21,563,861
etc.
