Photo set not forming a consolidated image
https://1drv.ms/u/s!Auv-5QlGCPQogZUb9CkP_GOqbD1zyQ?e=dnJbRc
Good evening, I have been using lightning for a while and rarely have any issues. I have geotagged the above photoset in mission planner and they appear to be tagged correctly however when processed I do not get a consolidated image.
I’m hoping someone could process / interpret what is going on
Kindly
Steve
https://1drv.ms/u/s!Auv-5QlGCPQogZ4aSrHwEm9ozQmsNA?e=DfVWbH
This is the output image I’m getting ATM
Steve
It’s possible that the model might be upside down (the Z axis could be flipped).
You said you manually geotagged the images? Did you add a vertical component to the images too? Where did the geo data come from?
How does the 3D model look like?
Were you using a dataflash log to do the GeoTagging? Flying a 3DR Solo or something similar?
It looks like some of the attributes weren’t transferred to the GeoTags (namely direction and rotation) [though this shouldn’t really matter much].
At a quick glance, does this seem to represent your flight path properly (begin at red *, stop at blue +)?
I also noticed that seemingly, your camera might have had its accelerometer on for auto-rotating/leveling of the photos, so your effective sidelap/overlap seems to be changing randomly throughout the flight, which certainly could affect reconstruction negatively, especially if you designed the flightplan with the wide-axis perpendicular to the flight path and it collected a number of images with the long axis perpendicular to the flight path.
I have adjusted the the geotagging height its was registering a GPS height of 200 rather then the height of 80m AGL per the flight plan- which was correct for the flight - it looked like this might have fixed the problem but I have a new log, the logs do suggest also Z axis might be flipped . > to poor GSD. I have not done a 3D model just fast ortho, I have modelled this property many times for maintenance and proficiency.
@Saijin_Naib, I will go in and check camera settings particularly accelerometer. I tried to go through adjust the photos all manually- Geotagging was done with mission planner using dataflash, with a flight plan as you state long axis perpendicular. the CSV file has Lat Long, Hgt, direction tilt yaw and roll recorded - though I only see Lat long and Hgt when looking at exif data in photos.
Unfortunately I have just checked and I cannot change the auto rotation on Sony A6000.
Below is the task output summary with new HGT data in exif …it was looking promising but now nearly 3 hrs on the last line.
https://1drv.ms/t/s!Auv-5QlGCPQogZ4bvwSeXiVHIhY7dg?e=ZxWy40
I am pleased - I have removed all my very bad images with>10deg tilt and images have processed - lost about 1/2 of my data ( but at lest now I have an image to show for it. Thankyou for all your suggestion and advice
Glad you’ve found success!
Don’t feel too bad, pruning data is all part of the process. I had numerous times where I had to throw out bad photos when doing Agricultural Field Survey work.
Hmm… I wonder if we might need to ask Michael Oborne to expand the tags that the Mission Planner Geotagging program writes out to the images to include things like dir/yaw/tilt/roll, etc.
