Permissions error
Hello, I’ve recently started using ODM on Linux… I got it installed and it runs, but if I run it with just “./webodm.sh start” I get this error message:
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm=1
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 665, in urlopen
httplib_response = self._make_request(
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.8/http/client.py”, line 1252, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1298, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1247, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1007, in _send_output
self.send(msg)
File “/usr/lib/python3.8/http/client.py”, line 947, in send
self.connect()
File “/usr/local/lib/python3.8/dist-packages/docker/transport/unixconn.py”, line 43, in connect
sock.connect(self.unix_socket)
PermissionError: [Errno 13] Permission denied
If I run it with the sudo account, it runs but then I get the message that it’s not recommended to do that!
What should the rights be on what gets run? Should they all be under my login account? Some files have rights have “root” rights and “root” and “staff”…
Harold
sudo usermod -aG docker $USER
exit
(restart shell by logging out and then back-in)
./webodm.sh start
This worked! Thanks!
Harold
