Passing an options file
Is it possible to pass an options file to the native Windows version of ODM?
I often mistype the options or forget something, so I end up with inconsistent runs.
Oh that’s an interesting question… Maybe you could read out from a file and pipe it over to ODM, but I have never tried.
cmd or PowerShell?
ODM Console, but looks like a CMD window.
You can use a settings.yaml file. It’s not very well documented, but you can put it in your project folder to use it instead of passing command line options.
Thanks, I got it working when editing settings.yaml in C:/ODM (install location) but not from the project folder.
