Parse error, v. 2.6.4 - only with GCP file
I’m having trouble finishing a processing job of approx. 300 images, cross-grid flight. This only happens when adding a GCP file to the processing, without it the job finishes as usual. Using the latest ODM V2.6.4, native Windows installation.
I have installed ODM at drive D:\ODM
Job is stored at drive C:\drohne, but I have tried processing it at Drive D:\drohne aswell, same result
Here are the last lines from the console:
[INFO] running pdal translate -i “c:\drohne\odm_filterpoints\point_cloud.ply” -o “c:\drohne\odm_georeferencing\odm_georeferenced_model.laz” ferry transformation --filters.ferry.dimensions=“views => UserData” --writers.las.compression=“lazip” --filters.transformation.matrix=“1 0 0 313103.0 0 1 0 5227557.0 0 0 1 0 0 0 0 1” --writers.las.offset_x=313103.0 --writers.las.offset_y=5227557.0 --writers.las.offset_z=0 --writers.las.a_srs="+proj=utm +zone=33 +datum=WGS84 +units=m +no_defs +type=crs" --writers.las.vlrs="{“filename”: “c:\drohne\odm_georeferencing\ground_control_points.gml”, “user_id”: “ODM_GCP”, “description”: “Ground Control Points (GML)”}"
PDAL: [json.exception.parse_error.101] parse error at line 1, column 18: syntax error while parsing value - invalid string: forbidden character after backslash; last read: ‘"c:\d’
Child returned 1
File “D:\ODM\stages\odm_app.py”, line 94, in execute
File “D:\ODM\opendm\types.py”, line 341, in run
[Previous line repeated 5 more times]
File “D:\ODM\opendm\types.py”, line 322, in run
File “D:\ODM\stages\odm_georeferencing.py”, line 131, in process
system.run(cmd + ’ ’ + ’ '.join(stages) + ’ ’ + ’ '.join(params))
File “D:\ODM\opendm\system.py”, line 106, in run
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying.html
For reference, here is the GCP file, added to the job as gcp_list.txt:
Any guesses what might solve the issue?
kind regards
David
It’s a bug; thanks for reporting it! :pray:
Fix coming shortly…
Should be fixed! Please update and try again?
Wow, thanks for your quick action Piero.
Unfortunately, the minor update didn’t solve the issue.
I downloaded the newest ODM_Setup_2.6.4.exe from the release site… Release 2.6.4 · OpenDroneMap/ODM · GitHub
… did a clean install (uninstall prior ODM installation, install newly downloaded EXE) and ran the job again. Here is the console output:
2021-09-29 09:18:26,216 DEBUG: Set field error_z: -0.7529081090760883
2021-09-29 09:18:26,216 DEBUG: Comitting transaction (final)
2021-09-29 09:18:26,217 DEBUG: Exiting env context: <fiona.env.Env object at 0x000001EA39113820>
2021-09-29 09:18:26,217 DEBUG: Cleared existing <fiona._env.GDALEnv object at 0x000001EA391132B0> options
2021-09-29 09:18:26,217 DEBUG: Stopping GDALEnv <fiona._env.GDALEnv object at 0x000001EA391132B0>.
2021-09-29 09:18:26,217 DEBUG: Error handler popped.
2021-09-29 09:18:26,217 DEBUG: Stopped GDALEnv <fiona._env.GDALEnv object at 0x000001EA391132B0>.
2021-09-29 09:18:26,217 DEBUG: Exiting outermost env
2021-09-29 09:18:26,217 DEBUG: Exited env context: <fiona.env.Env object at 0x000001EA39113820>
2021-09-29 09:18:26,223 DEBUG: Flushed data source cache
2021-09-29 09:18:26,223 DEBUG: Flushed buffer
2021-09-29 09:18:26,224 DEBUG: Stopped session
[INFO] running ogr2ogr -of GML “d:\WORK_LOKAL\16531\drohne\odm_georeferencing\ground_control_points.gml” “d:\WORK_LOKAL\16531\drohne\odm_georeferencing\ground_control_points.gpkg”
[INFO] Georeferencing point cloud
[INFO] Embedding GCP info in point cloud
[INFO] running pdal translate -i “d:\WORK_LOKAL\16531\drohne\odm_filterpoints\point_cloud.ply” -o “d:\WORK_LOKAL\16531\drohne\odm_georeferencing\odm_georeferenced_model.laz” ferry transformation --filters.ferry.dimensions=“views => UserData” --writers.las.compression=“lazip” --filters.transformation.matrix=“1 0 0 313103.0 0 1 0 5227557.0 0 0 1 0 0 0 0 1” --writers.las.offset_x=313103.0 --writers.las.offset_y=5227557.0 --writers.las.offset_z=0 --writers.las.a_srs="+proj=utm +zone=33 +datum=WGS84 +units=m +no_defs +type=crs" --writers.las.vlrs="{“filename”: “d:\WORK_LOKAL\16531\drohne\odm_georeferencing\ground_control_points.gml”, “user_id”: “ODM_GCP”, “description”: “Ground Control Points (GML)”}"
PDAL: [json.exception.parse_error.101] parse error at line 1, column 18: syntax error while parsing value - invalid string: forbidden character after backslash; last read: ‘"d:\W’
Child returned 1
Update:
I uninstalled v2.6.4, downloaded v2.5.7 → was able to finish the job successfully with 2.5.7 from the state where 2.6.4 had aborted :slightly_smiling_face:
Ooh, thanks for helping us track down/confirm the regression came after 2.5.7!
Of course, nothing to thank for. It’s rather me having to thank you for your effort with the program :slightly_smiling_face:
Ups, I don’t think the 2.6.4 setup.exe rebuilt. Try now, it should work.
It did! Thank’s again, great work :smiley:
