So I know in the tutorial for WebODM is says that in order to get the best results you should fly two overlapping flight plans over the same area offset by 20 degrees. My question is do you need to have the drone’s starting and ending points be opposite for both flights since I have been always taught you want to have the drone flying into the wind when doing mapping missions for safety reasons.
Thanks!
