Greetings,
I just downloaded WebODB. Tried my first proyect and there was an output error.
There may be several reasons:
Dockers wont install, this message comes up: Docker Desktop requires Windows 10 Pro/Enterprise (15063+) or Windows 10 Home (19018+).
Images Link: https://drive.google.com/drive/folders/1FNgL_rzBOJZJHb1UO0EccreixdJ_wlVe?usp=sharing
Note: I have used these same images in MapsMadeEasy, DroneDeply and Pix4D and they work well, creating 3D models.
I tuned my WebODM parameteres. CPU to 15 (16 max) and RAM to 14000 (16000 max). Haven’t done it in Dockers since it does not install.
I’m running on Windows 10 Home, 16GB Ram, AMD Ryzen 4000, Nvidia 2060, SSD 1T. I navigate using Firefox.
Code output result: https://docs.google.com/document/d/1-IVXyCGY035-BjG0-eVRWQgJKl4_kRjm3jaLTCFODrs/edit?usp=sharing
It looks like your processing node ran out of memory. If you are using docker, make sure that your docker environment has [enough RAM allocated]. Alternatively, make sure you have enough physical RAM, reduce the number of images, make your images smaller, or reduce the max-concurrency parameter from the task’s [options](javascript:void(0);). You can also try to use a [cloud processing node]
Thank you
