Out Of Memory - help me!
[INFO] Initializing ODM - Sat Oct 23 13:42:50 2021
[INFO] ==============
[INFO] auto_boundary: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: True
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 2
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 98f3020e-98bb-4a52-9fbf-5cf1fdc10f40
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: high
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/98f3020e-98bb-4a52-9fbf-5cf1fdc10f40/images
[INFO] Loading 51 images
[INFO] Wrote images database: /var/www/data/98f3020e-98bb-4a52-9fbf-5cf1fdc10f40/images.json
[INFO] Found 51 usable images
[INFO] Parsing SRS header: WGS84 UTM 48N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 5472px
[INFO] Photo dimensions for feature extraction: 2736px
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2736’, ‘feature_min_frames: 8000’, ‘processes: 2’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /code/SuperBuild/install/bin/opensfm/bin/opensfm extract_metadata “/var/www/data/98f3020e-98bb-4a52-9fbf-5cf1fdc10f40/opensfm”
2021-10-23 13:42:51,792 INFO: Extracting EXIF for 100_0214_0033.JPG
2021-10-23 13:42:51,906 INFO: Extracting EXIF for 100_0214_0016.JPG
2021-10-23 13:42:52,005 INFO: Extracting EXIF for 100_0214_0048.JPG
2021-10-23 13:42:52,154 INFO: Extracting EXIF for 100_0214_0023.JPG
2021-10-23 13:42:52,257 INFO: Extracting EXIF for 100_0214_0028.JPG
2021-10-23 13:42:52,362 INFO: Extracting EXIF for 100_0214_0005.JPG
2021-10-23 13:42:52,462 INFO: Extracting EXIF for 100_0214_0018.JPG
2021-10-23 13:42:52,562 INFO: Extracting EXIF for 100_0214_0021.JPG
2021-10-23 13:42:52,661 INFO: Extracting EXIF for 100_0214_0008.JPG
2021-10-23 13:42:52,761 INFO: Extracting EXIF for 100_0214_0031.JPG
2021-10-23 13:42:52,861 INFO: Extracting EXIF for 100_0214_0046.JPG
2021-10-23 13:42:52,958 INFO: Extracting EXIF for 100_0214_0010.JPG
2021-10-23 13:42:53,058 INFO: Extracting EXIF for 100_0214_0047.JPG
2021-10-23 13:42:53,159 INFO: Extracting EXIF for 100_0214_0013.JPG
2021-10-23 13:42:53,261 INFO: Extracting EXIF for 100_0214_0006.JPG
2021-10-23 13:42:53,360 INFO: Extracting EXIF for 100_0214_0025.JPG
2021-10-23 13:42:53,462 INFO: Extracting EXIF for 100_0214_0020.JPG
2021-10-23 13:42:53,560 INFO: Extracting EXIF for 100_0214_0024.JPG
2021-10-23 13:42:53,656 INFO: Extracting EXIF for 100_0214_0050.JPG
2021-10-23 13:42:53,757 INFO: Extracting EXIF for 100_0214_0001.JPG
2021-10-23 13:42:53,856 INFO: Extracting EXIF for 100_0214_0044.JPG
2021-10-23 13:42:53,974 INFO: Extracting EXIF for 100_0214_0015.JPG
2021-10-23 13:42:54,075 INFO: Extracting EXIF for 100_0214_0043.JPG
2021-10-23 13:42:54,173 INFO: Extracting EXIF for 100_0214_0038.JPG
2021-10-23 13:42:54,273 INFO: Extracting EXIF for 100_0214_0051.JPG
2021-10-23 13:42:54,377 INFO: Extracting EXIF for 100_0214_0042.JPG
2021-10-23 13:42:54,477 INFO: Extracting EXIF for 100_0214_0012.JPG
2021-10-23 13:42:54,581 INFO: Extracting EXIF for 100_0214_0029.JPG
2021-10-23 13:42:54,683 INFO: Extracting EXIF for 100_0214_0003.JPG
2021-10-23 13:42:54,784 INFO: Extracting EXIF for 100_0214_0040.JPG
2021-10-23 13:42:54,884 INFO: Extracting EXIF for 100_0214_0007.JPG
2021-10-23 13:42:54,981 INFO: Extracting EXIF for 100_0214_0036.JPG
2021-10-23 13:42:55,082 INFO: Extracting EXIF for 100_0214_0034.JPG
2021-10-23 13:42:55,181 INFO: Extracting EXIF for 100_0214_0022.JPG
2021-10-23 13:42:55,280 INFO: Extracting EXIF for 100_0214_0049.JPG
2021-10-23 13:42:55,380 INFO: Extracting EXIF for 100_0214_0037.JPG
2021-10-23 13:42:55,478 INFO: Extracting EXIF for 100_0214_0019.JPG
2021-10-23 13:42:55,576 INFO: Extracting EXIF for 100_0214_0030.JPG
2021-10-23 13:42:55,677 INFO: Extracting EXIF for 100_0214_0004.JPG
2021-10-23 13:42:55,776 INFO: Extracting EXIF for 100_0214_0017.JPG
2021-10-23 13:42:55,875 INFO: Extracting EXIF for 100_0214_0026.JPG
2021-10-23 13:42:55,975 INFO: Extracting EXIF for 100_0214_0032.JPG
2021-10-23 13:42:56,075 INFO: Extracting EXIF for 100_0214_0045.JPG
2021-10-23 13:42:56,194 INFO: Extracting EXIF for 100_0214_0039.JPG
2021-10-23 13:42:56,293 INFO: Extracting EXIF for 100_0214_0035.JPG
2021-10-23 13:42:56,392 INFO: Extracting EXIF for 100_0214_0009.JPG
2021-10-23 13:42:56,491 INFO: Extracting EXIF for 100_0214_0002.JPG
2021-10-23 13:42:56,591 INFO: Extracting EXIF for 100_0214_0027.JPG
2021-10-23 13:42:56,694 INFO: Extracting EXIF for 100_0214_0011.JPG
2021-10-23 13:42:56,794 INFO: Extracting EXIF for 100_0214_0014.JPG
[INFO] running /code/SuperBuild/install/bin/opensfm/bin/opensfm detect_features “/var/www/data/98f3020e-98bb-4a52-9fbf-5cf1fdc10f40/opensfm”
2021-10-23 13:42:57,868 INFO: Capping memory usage to ~ 1204.466796875 MB
2021-10-23 13:42:57,868 INFO: Expecting to process 15 images.
2021-10-23 13:42:57,873 INFO: Reading data for image 100_0214_0041.JPG (queue-size=0
2021-10-23 13:42:58,670 INFO: Reading data for image 100_0214_0033.JPG (queue-size=1
2021-10-23 13:42:58,671 INFO: Extracting ROOT_SIFT features for image 100_0214_0041.JPG
2021-10-23 13:42:58,702 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:42:59,100 INFO: Reading data for image 100_0214_0016.JPG (queue-size=1
2021-10-23 13:42:59,517 INFO: Reading data for image 100_0214_0048.JPG (queue-size=2
2021-10-23 13:42:59,959 INFO: Reading data for image 100_0214_0023.JPG (queue-size=3
2021-10-23 13:43:00,805 INFO: Reading data for image 100_0214_0028.JPG (queue-size=4
2021-10-23 13:43:01,648 INFO: Reading data for image 100_0214_0005.JPG (queue-size=5
2021-10-23 13:43:01,744 DEBUG: Found 14082 points in 3.039888381958008s
2021-10-23 13:43:01,744 DEBUG: done
2021-10-23 13:43:02,132 INFO: Reading data for image 100_0214_0018.JPG (queue-size=6
2021-10-23 13:43:02,620 INFO: Reading data for image 100_0214_0021.JPG (queue-size=7
2021-10-23 13:43:03,056 INFO: Reading data for image 100_0214_0008.JPG (queue-size=8
2021-10-23 13:43:03,506 INFO: Reading data for image 100_0214_0031.JPG (queue-size=9
2021-10-23 13:43:03,540 DEBUG: No segmentation for 100_0214_0041.JPG, no features masked.
2021-10-23 13:43:03,895 INFO: Extracting ROOT_SIFT features for image 100_0214_0033.JPG
2021-10-23 13:43:03,911 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:03,958 INFO: Reading data for image 100_0214_0046.JPG (queue-size=9
2021-10-23 13:43:04,381 INFO: Reading data for image 100_0214_0010.JPG (queue-size=10
2021-10-23 13:43:04,901 INFO: Reading data for image 100_0214_0047.JPG (queue-size=11
2021-10-23 13:43:05,867 INFO: Reading data for image 100_0214_0013.JPG (queue-size=12
2021-10-23 13:43:06,402 DEBUG: Found 11053 points in 2.491103410720825s
2021-10-23 13:43:06,402 DEBUG: done
2021-10-23 13:43:06,677 INFO: Reading data for image 100_0214_0006.JPG (queue-size=13
2021-10-23 13:43:07,463 INFO: Reading data for image 100_0214_0025.JPG (queue-size=14
2021-10-23 13:43:07,991 INFO: Reading data for image 100_0214_0020.JPG (queue-size=15
2021-10-23 13:43:08,076 DEBUG: No segmentation for 100_0214_0033.JPG, no features masked.
2021-10-23 13:43:08,373 INFO: Extracting ROOT_SIFT features for image 100_0214_0016.JPG
2021-10-23 13:43:08,389 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:08,524 INFO: Reading data for image 100_0214_0024.JPG (queue-size=15
2021-10-23 13:43:10,436 DEBUG: Found 16436 points in 2.0466420650482178s
2021-10-23 13:43:10,436 DEBUG: done
2021-10-23 13:43:12,213 DEBUG: No segmentation for 100_0214_0016.JPG, no features masked.
2021-10-23 13:43:12,596 INFO: Reading data for image 100_0214_0050.JPG (queue-size=15
2021-10-23 13:43:12,596 INFO: Extracting ROOT_SIFT features for image 100_0214_0048.JPG
2021-10-23 13:43:12,620 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:14,731 DEBUG: Found 13350 points in 2.1106457710266113s
2021-10-23 13:43:14,731 DEBUG: done
2021-10-23 13:43:16,530 DEBUG: No segmentation for 100_0214_0048.JPG, no features masked.
2021-10-23 13:43:16,842 INFO: Reading data for image 100_0214_0001.JPG (queue-size=15
2021-10-23 13:43:16,842 INFO: Extracting ROOT_SIFT features for image 100_0214_0023.JPG
2021-10-23 13:43:16,858 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:18,792 DEBUG: Found 13683 points in 1.9336416721343994s
2021-10-23 13:43:18,792 DEBUG: done
2021-10-23 13:43:20,427 DEBUG: No segmentation for 100_0214_0023.JPG, no features masked.
2021-10-23 13:43:20,744 INFO: Reading data for image 100_0214_0044.JPG (queue-size=15
2021-10-23 13:43:20,744 INFO: Extracting ROOT_SIFT features for image 100_0214_0028.JPG
2021-10-23 13:43:20,760 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:22,783 DEBUG: Found 10604 points in 2.023019313812256s
2021-10-23 13:43:22,784 DEBUG: done
2021-10-23 13:43:24,326 DEBUG: No segmentation for 100_0214_0028.JPG, no features masked.
2021-10-23 13:43:24,574 INFO: Reading data for image 100_0214_0015.JPG (queue-size=15
2021-10-23 13:43:24,575 INFO: Extracting ROOT_SIFT features for image 100_0214_0005.JPG
2021-10-23 13:43:24,591 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:26,615 DEBUG: Found 16700 points in 2.024385452270508s
2021-10-23 13:43:26,616 DEBUG: done
2021-10-23 13:43:28,414 DEBUG: No segmentation for 100_0214_0005.JPG, no features masked.
2021-10-23 13:43:28,805 INFO: Reading data for image 100_0214_0043.JPG (queue-size=15
2021-10-23 13:43:28,806 INFO: Extracting ROOT_SIFT features for image 100_0214_0018.JPG
2021-10-23 13:43:28,821 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:30,817 DEBUG: Found 13655 points in 1.9959094524383545s
2021-10-23 13:43:30,818 DEBUG: done
2021-10-23 13:43:32,492 DEBUG: No segmentation for 100_0214_0018.JPG, no features masked.
2021-10-23 13:43:32,809 INFO: Reading data for image 100_0214_0038.JPG (queue-size=15
2021-10-23 13:43:32,810 INFO: Extracting ROOT_SIFT features for image 100_0214_0021.JPG
2021-10-23 13:43:32,825 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:34,759 DEBUG: Found 12969 points in 1.9334793090820312s
2021-10-23 13:43:34,759 DEBUG: done
2021-10-23 13:43:36,354 DEBUG: No segmentation for 100_0214_0021.JPG, no features masked.
2021-10-23 13:43:36,653 INFO: Reading data for image 100_0214_0051.JPG (queue-size=15
2021-10-23 13:43:36,654 INFO: Extracting ROOT_SIFT features for image 100_0214_0008.JPG
2021-10-23 13:43:36,676 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:38,674 DEBUG: Found 18769 points in 1.9983694553375244s
2021-10-23 13:43:38,674 DEBUG: done
2021-10-23 13:43:40,546 DEBUG: No segmentation for 100_0214_0008.JPG, no features masked.
2021-10-23 13:43:40,984 INFO: Reading data for image 100_0214_0042.JPG (queue-size=15
2021-10-23 13:43:40,984 INFO: Extracting ROOT_SIFT features for image 100_0214_0031.JPG
2021-10-23 13:43:41,000 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:43,076 DEBUG: Found 11900 points in 2.076219081878662s
2021-10-23 13:43:43,077 DEBUG: done
2021-10-23 13:43:44,666 DEBUG: No segmentation for 100_0214_0031.JPG, no features masked.
2021-10-23 13:43:44,951 INFO: Reading data for image 100_0214_0012.JPG (queue-size=15
2021-10-23 13:43:44,952 INFO: Extracting ROOT_SIFT features for image 100_0214_0046.JPG
2021-10-23 13:43:44,967 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:46,939 DEBUG: Found 11614 points in 1.970982551574707s
2021-10-23 13:43:46,939 DEBUG: done
2021-10-23 13:43:48,539 DEBUG: No segmentation for 100_0214_0046.JPG, no features masked.
2021-10-23 13:43:48,811 INFO: Reading data for image 100_0214_0029.JPG (queue-size=15
2021-10-23 13:43:48,811 INFO: Extracting ROOT_SIFT features for image 100_0214_0010.JPG
2021-10-23 13:43:48,827 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:50,865 DEBUG: Found 18028 points in 2.0377860069274902s
2021-10-23 13:43:50,865 DEBUG: done
2021-10-23 13:43:52,746 DEBUG: No segmentation for 100_0214_0010.JPG, no features masked.
2021-10-23 13:43:53,171 INFO: Reading data for image 100_0214_0003.JPG (queue-size=15
2021-10-23 13:43:53,171 INFO: Extracting ROOT_SIFT features for image 100_0214_0047.JPG
2021-10-23 13:43:53,187 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:55,143 DEBUG: Found 12263 points in 1.9550206661224365s
2021-10-23 13:43:55,143 DEBUG: done
2021-10-23 13:43:56,757 DEBUG: No segmentation for 100_0214_0047.JPG, no features masked.
2021-10-23 13:43:57,045 INFO: Reading data for image 100_0214_0040.JPG (queue-size=15
2021-10-23 13:43:57,045 INFO: Extracting ROOT_SIFT features for image 100_0214_0013.JPG
2021-10-23 13:43:57,061 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:43:59,083 DEBUG: Found 19845 points in 2.0215024948120117s
2021-10-23 13:43:59,083 DEBUG: done
2021-10-23 13:44:00,978 DEBUG: No segmentation for 100_0214_0013.JPG, no features masked.
2021-10-23 13:44:01,446 INFO: Reading data for image 100_0214_0007.JPG (queue-size=15
2021-10-23 13:44:01,446 INFO: Extracting ROOT_SIFT features for image 100_0214_0006.JPG
2021-10-23 13:44:01,461 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:03,430 DEBUG: Found 15335 points in 1.9689807891845703s
2021-10-23 13:44:03,431 DEBUG: done
2021-10-23 13:44:05,175 DEBUG: No segmentation for 100_0214_0006.JPG, no features masked.
2021-10-23 13:44:05,532 INFO: Extracting ROOT_SIFT features for image 100_0214_0025.JPG
2021-10-23 13:44:05,533 INFO: Reading data for image 100_0214_0036.JPG (queue-size=15
2021-10-23 13:44:05,548 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:07,526 DEBUG: Found 14552 points in 1.9773154258728027s
2021-10-23 13:44:07,526 DEBUG: done
2021-10-23 13:44:09,198 DEBUG: No segmentation for 100_0214_0025.JPG, no features masked.
2021-10-23 13:44:09,535 INFO: Reading data for image 100_0214_0034.JPG (queue-size=15
2021-10-23 13:44:09,535 INFO: Extracting ROOT_SIFT features for image 100_0214_0020.JPG
2021-10-23 13:44:09,550 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:11,506 DEBUG: Found 12253 points in 1.955911636352539s
2021-10-23 13:44:11,507 DEBUG: done
2021-10-23 13:44:13,129 DEBUG: No segmentation for 100_0214_0020.JPG, no features masked.
2021-10-23 13:44:13,414 INFO: Reading data for image 100_0214_0022.JPG (queue-size=15
2021-10-23 13:44:13,414 INFO: Extracting ROOT_SIFT features for image 100_0214_0024.JPG
2021-10-23 13:44:13,436 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:15,404 DEBUG: Found 13679 points in 1.967499017715454s
2021-10-23 13:44:15,404 DEBUG: done
2021-10-23 13:44:17,178 DEBUG: No segmentation for 100_0214_0024.JPG, no features masked.
2021-10-23 13:44:17,507 INFO: Reading data for image 100_0214_0049.JPG (queue-size=15
2021-10-23 13:44:17,507 INFO: Extracting ROOT_SIFT features for image 100_0214_0050.JPG
2021-10-23 13:44:17,523 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:19,566 DEBUG: Found 13329 points in 2.0432796478271484s
2021-10-23 13:44:19,567 DEBUG: done
2021-10-23 13:44:21,227 DEBUG: No segmentation for 100_0214_0050.JPG, no features masked.
2021-10-23 13:44:21,580 INFO: Reading data for image 100_0214_0037.JPG (queue-size=15
2021-10-23 13:44:21,580 INFO: Extracting ROOT_SIFT features for image 100_0214_0001.JPG
2021-10-23 13:44:21,603 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:23,676 DEBUG: Found 16104 points in 2.0729146003723145s
2021-10-23 13:44:23,676 DEBUG: done
2021-10-23 13:44:25,417 DEBUG: No segmentation for 100_0214_0001.JPG, no features masked.
2021-10-23 13:44:25,794 INFO: Reading data for image 100_0214_0019.JPG (queue-size=15
2021-10-23 13:44:25,794 INFO: Extracting ROOT_SIFT features for image 100_0214_0044.JPG
2021-10-23 13:44:25,809 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:27,885 DEBUG: Found 12402 points in 2.075765371322632s
2021-10-23 13:44:27,886 DEBUG: done
2021-10-23 13:44:29,487 DEBUG: No segmentation for 100_0214_0044.JPG, no features masked.
2021-10-23 13:44:29,776 INFO: Reading data for image 100_0214_0030.JPG (queue-size=15
2021-10-23 13:44:29,776 INFO: Extracting ROOT_SIFT features for image 100_0214_0015.JPG
2021-10-23 13:44:29,792 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:31,824 DEBUG: Found 18662 points in 2.031879186630249s
2021-10-23 13:44:31,824 DEBUG: done
2021-10-23 13:44:33,863 DEBUG: No segmentation for 100_0214_0015.JPG, no features masked.
2021-10-23 13:44:34,299 INFO: Reading data for image 100_0214_0004.JPG (queue-size=15
2021-10-23 13:44:34,300 INFO: Extracting ROOT_SIFT features for image 100_0214_0043.JPG
2021-10-23 13:44:34,316 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:36,347 DEBUG: Found 12373 points in 2.030709743499756s
2021-10-23 13:44:36,347 DEBUG: done
2021-10-23 13:44:38,115 DEBUG: No segmentation for 100_0214_0043.JPG, no features masked.
2021-10-23 13:44:38,416 INFO: Reading data for image 100_0214_0017.JPG (queue-size=15
2021-10-23 13:44:38,416 INFO: Extracting ROOT_SIFT features for image 100_0214_0038.JPG
2021-10-23 13:44:38,431 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:40,163 DEBUG: Found 1731 points in 1.7313859462738037s
2021-10-23 13:44:40,163 DEBUG: reducing threshold
2021-10-23 13:44:40,163 DEBUG: Computing sift with threshold 0.044000000000000004
2021-10-23 13:44:42,130 DEBUG: Found 6279 points in 1.966601848602295s
2021-10-23 13:44:42,130 DEBUG: reducing threshold
2021-10-23 13:44:42,130 DEBUG: Computing sift with threshold 0.029333333333333336
2021-10-23 13:44:44,155 DEBUG: Found 15245 points in 2.0244858264923096s
2021-10-23 13:44:44,155 DEBUG: done
2021-10-23 13:44:45,989 DEBUG: No segmentation for 100_0214_0038.JPG, no features masked.
2021-10-23 13:44:46,365 INFO: Reading data for image 100_0214_0026.JPG (queue-size=15
2021-10-23 13:44:46,365 INFO: Extracting ROOT_SIFT features for image 100_0214_0051.JPG
2021-10-23 13:44:46,381 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:48,334 DEBUG: Found 13027 points in 1.9531559944152832s
2021-10-23 13:44:48,334 DEBUG: done
2021-10-23 13:44:50,023 DEBUG: No segmentation for 100_0214_0051.JPG, no features masked.
2021-10-23 13:44:50,332 INFO: Reading data for image 100_0214_0032.JPG (queue-size=15
2021-10-23 13:44:50,332 INFO: Extracting ROOT_SIFT features for image 100_0214_0042.JPG
2021-10-23 13:44:50,348 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:52,406 DEBUG: Found 13313 points in 2.057884693145752s
2021-10-23 13:44:52,406 DEBUG: done
2021-10-23 13:44:54,044 DEBUG: No segmentation for 100_0214_0042.JPG, no features masked.
2021-10-23 13:44:54,353 INFO: Reading data for image 100_0214_0045.JPG (queue-size=15
2021-10-23 13:44:54,353 INFO: Extracting ROOT_SIFT features for image 100_0214_0012.JPG
2021-10-23 13:44:54,375 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:44:56,421 DEBUG: Found 18138 points in 2.0456278324127197s
2021-10-23 13:44:56,421 DEBUG: done
2021-10-23 13:44:58,232 DEBUG: No segmentation for 100_0214_0012.JPG, no features masked.
2021-10-23 13:44:58,652 INFO: Reading data for image 100_0214_0039.JPG (queue-size=15
2021-10-23 13:44:58,652 INFO: Extracting ROOT_SIFT features for image 100_0214_0029.JPG
2021-10-23 13:44:58,668 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:00,594 DEBUG: Found 12351 points in 1.925894021987915s
2021-10-23 13:45:00,594 DEBUG: done
2021-10-23 13:45:02,250 DEBUG: No segmentation for 100_0214_0029.JPG, no features masked.
2021-10-23 13:45:02,541 INFO: Reading data for image 100_0214_0035.JPG (queue-size=15
2021-10-23 13:45:02,542 INFO: Extracting ROOT_SIFT features for image 100_0214_0003.JPG
2021-10-23 13:45:02,565 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:04,553 DEBUG: Found 13961 points in 1.9882080554962158s
2021-10-23 13:45:04,553 DEBUG: done
2021-10-23 13:45:06,269 DEBUG: No segmentation for 100_0214_0003.JPG, no features masked.
2021-10-23 13:45:06,616 INFO: Extracting ROOT_SIFT features for image 100_0214_0040.JPG
2021-10-23 13:45:06,616 INFO: Reading data for image 100_0214_0009.JPG (queue-size=15
2021-10-23 13:45:06,632 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:08,595 DEBUG: Found 12247 points in 1.9625132083892822s
2021-10-23 13:45:08,595 DEBUG: done
2021-10-23 13:45:10,195 DEBUG: No segmentation for 100_0214_0040.JPG, no features masked.
2021-10-23 13:45:10,477 INFO: Extracting ROOT_SIFT features for image 100_0214_0007.JPG
2021-10-23 13:45:10,477 INFO: Reading data for image 100_0214_0002.JPG (queue-size=15
2021-10-23 13:45:10,493 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:12,545 DEBUG: Found 16110 points in 2.0516672134399414s
2021-10-23 13:45:12,545 DEBUG: done
2021-10-23 13:45:14,347 DEBUG: No segmentation for 100_0214_0007.JPG, no features masked.
2021-10-23 13:45:14,720 INFO: Extracting ROOT_SIFT features for image 100_0214_0036.JPG
2021-10-23 13:45:14,721 INFO: Reading data for image 100_0214_0027.JPG (queue-size=15
2021-10-23 13:45:14,737 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:16,708 DEBUG: Found 14255 points in 1.9711194038391113s
2021-10-23 13:45:16,708 DEBUG: done
2021-10-23 13:45:18,388 DEBUG: No segmentation for 100_0214_0036.JPG, no features masked.
2021-10-23 13:45:18,721 INFO: Reading data for image 100_0214_0011.JPG (queue-size=15
2021-10-23 13:45:18,721 INFO: Extracting ROOT_SIFT features for image 100_0214_0034.JPG
2021-10-23 13:45:18,744 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:20,717 DEBUG: Found 13602 points in 1.9720995426177979s
2021-10-23 13:45:20,717 DEBUG: done
2021-10-23 13:45:22,395 DEBUG: No segmentation for 100_0214_0034.JPG, no features masked.
2021-10-23 13:45:22,715 INFO: Reading data for image 100_0214_0014.JPG (queue-size=15
2021-10-23 13:45:22,715 INFO: Extracting ROOT_SIFT features for image 100_0214_0022.JPG
2021-10-23 13:45:22,731 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:24,669 DEBUG: Found 12757 points in 1.9373128414154053s
2021-10-23 13:45:24,669 DEBUG: done
2021-10-23 13:45:26,269 DEBUG: No segmentation for 100_0214_0022.JPG, no features masked.
2021-10-23 13:45:26,565 INFO: Extracting ROOT_SIFT features for image 100_0214_0049.JPG
2021-10-23 13:45:26,565 INFO: Finished reading images
2021-10-23 13:45:26,581 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:28,498 DEBUG: Found 12838 points in 1.9169681072235107s
2021-10-23 13:45:28,499 DEBUG: done
2021-10-23 13:45:30,087 DEBUG: No segmentation for 100_0214_0049.JPG, no features masked.
2021-10-23 13:45:30,386 INFO: Extracting ROOT_SIFT features for image 100_0214_0037.JPG
2021-10-23 13:45:30,388 INFO: Extracting ROOT_SIFT features for image 100_0214_0019.JPG
2021-10-23 13:45:30,404 DEBUG: Computing sift with threshold 0.066
2021-10-23 13:45:30,405 DEBUG: Computing sift with threshold 0.066
File “/code/SuperBuild/install/bin/opensfm/bin/opensfm_main.py”, line 15, in
commands.command_runner(
File “/code/SuperBuild/install/bin/opensfm/opensfm/commands/command_runner.py”, line 38, in command_runner
command.run(data, args)
File “/code/SuperBuild/install/bin/opensfm/opensfm/commands/command.py”, line 12, in run
self.run_impl(data, args)
File “/code/SuperBuild/install/bin/opensfm/opensfm/commands/detect_features.py”, line 11, in run_impl
detect_features.run_dataset(dataset)
File “/code/SuperBuild/install/bin/opensfm/opensfm/actions/detect_features.py”, line 68, in run_dataset
parallel_map(process, arguments, processes, 1)
File “/code/SuperBuild/install/bin/opensfm/opensfm/context.py”, line 52, in parallel_map
res = Parallel(batch_size=batch_size)(delayed(func)(arg) for arg in args)
File “/usr/local/lib/python3.9/dist-packages/joblib/parallel.py”, line 1061, in call
self.retrieve()
File “/usr/local/lib/python3.9/dist-packages/joblib/parallel.py”, line 940, in retrieve
File “/usr/lib/python3.9/multiprocessing/pool.py”, line 771, in get
raise self._value
File “/usr/lib/python3.9/multiprocessing/pool.py”, line 125, in worker
result = (True, func(*args, **kwds))
File “/usr/local/lib/python3.9/dist-packages/joblib/_parallel_backends.py”, line 595, in call
return self.func(*args, **kwargs)
File “/usr/local/lib/python3.9/dist-packages/joblib/parallel.py”, line 262, in call
return [func(*args, **kwargs)
File “/code/SuperBuild/install/bin/opensfm/opensfm/actions/detect_features.py”, line 137, in process
run_detection(queue)
File “/code/SuperBuild/install/bin/opensfm/opensfm/actions/detect_features.py”, line 171, in run_detection
detect(image, image_array, segmentation_array, instances_array, data)
File “/code/SuperBuild/install/bin/opensfm/opensfm/actions/detect_features.py”, line 236, in detect
p_unmasked, f_unmasked, c_unmasked = features.extract_features(
File “/code/SuperBuild/install/bin/opensfm/opensfm/features.py”, line 560, in extract_features
points, desc = extract_features_sift(image_gray, config, features_count)
File “/code/SuperBuild/install/bin/opensfm/opensfm/features.py”, line 333, in extract_features_sift
points = detector.detect(image)
cv2.error: OpenCV(4.5.0) /code/SuperBuild/src/opencv/modules/core/src/alloc.cpp:73: error: (-4:Insufficient memory) Failed to allocate 79847424 bytes in function ‘OutOfMemoryError’
Child returned 1
File “/code/opendm/types.py”, line 347, in run
File “/code/opendm/types.py”, line 328, in run
File “/code/stages/run_opensfm.py”, line 35, in process
File “/code/opendm/osfm.py”, line 297, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 34, in run
system.run(’%s %s “%s”’ %
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 2.6.4 documentation
i put the webodm on my server, and that server is ubuntu 18.04 ,2core cpu , 4ram and 40g
, that i put the picture(51p) on it and it show this, my english is so bad , so , if you can teach me how to deal with this problem ,you can try to add my maybe can telegram (+085615985610338), please , (student cry)
Try again without --ignore-gsd. This option causes lots of problems, least of which is Out Of Memory crashes on many datasets.
You also have a very, very, very limited amount of RAM, so processing at HIGH quality for --feature-quality and --pc-quality is going to be difficult.
How much swap space do you have?
hello
The server is leased from a third-party organization that i check it show me the swap space is 0, :flushed:
i try it again ,no --ignore-gsd and midium --feature-quality 、midium --pc-quality
thank you
That’s unfortunate that they do not provide swap!
Are you able to request more swap, or will they make you pay more money?
they always want more money that i can pay for it , but maybe i can put this web on my own computer,that gpu:1660,cpu:3500x,16ram,maybe that is a best choice
