"command": "\"/code/SuperBuild/install/bin/odm_orthophoto\" -inputFiles /var/www/data/781d7c0d-aabf-4461-899d-fb631ab01eaf/odm_texturing_25d/odm_textured_model_geo.obj -logFile \"/var/www/data/781d7c0d-aabf-4461-899d-fb631ab01eaf/odm_orthophoto/odm_orthophoto_log.txt\" -outputFile \"/var/www/data/781d7c0d-aabf-4461-899d-fb631ab01eaf/odm_orthophoto/odm_orthophoto_render.tif\" -resolution 76.16090239023033 -verbose -outputCornerFile \"/var/www/data/781d7c0d-aabf-4461-899d-fb631ab01eaf/odm_orthophoto/odm_orthophoto_corners.txt\" ",
"exitCode": 137,
"output": [
"Boundary points:",
"Point 1: -2190.02 -661.017",
"Point 2: -2190.02 773.947",
"Point 3: 1194.01 773.947",
"Point 4: 1194.01 -661.017",
"Model bounds x : -2190.02 -> 1194.01",
"Model bounds y : -661.017 -> 773.947",
"Model area : 4.85596e+06m2",
"Killed"
"success": false,
"error": {
"code": 137,
"message": "Child returned 137"
"stackTrace": [
"Traceback (most recent call last):",
"File \"/code/stages/odm_app.py\", line 81, in execute",
"self.first_stage.run()",
"File \"/code/opendm/types.py\", line 386, in run",
"self.next_stage.run(outputs)",
"[Previous line repeated 7 more times]",
"File \"/code/opendm/types.py\", line 365, in run",
"self.process(self.args, outputs)",
"File \"/code/stages/odm_orthophoto.py\", line 85, in process",
"system.run('\"{odm_ortho_bin}\" -inputFiles {models} '",
"File \"/code/opendm/system.py\", line 109, in run",
"raise SubprocessException(\"Child returned {}\".format(retcode), retcode)",
"opendm.system.SubprocessException: Child returned 137",
"endTime": "2023-01-15T07:22:28.900061",
"totalTime": 64989.45
It was large data. It failed after 17-18 hours
