Orthophoto generation with GCP then also the orthophoto is not generated on the expected geolocation
In orthophoto generation I provide geotagged images with GCP then also the orthophoto is not generated on the expected location.
Welcome Sharu. Sorry for the trouble, can you provide screenshots,version of ODM, install process, and operating system. If possible can you also share the dataset?
For what it’s worth, I’m seeing something similar with a number of datasets:
I’m not sure, but I have my suspicions it might be related to this pull request:
This dataset is a submodel of a much larger project, so I’m running just the submodel through to discern whether this is a core issue, or some challenge associated with split-merge.
Thank u so much smathermather for the quick reply.
while using GCP,if i dont use --use-exif flag then the generated orthophoto goes to lon=0.00 lat=0.00 locations.
i pulled the latest docker image (opendronemap/odm:gpu )and run with it .
Do your images have proper EXIF, including GPSLatRef and GPSLongRef?
yes they do have! The same images get stitched well in Agisoft
even it generates orthomosaic on expected location without using GCPs!
How to do georeferncing with GCPs? do we need to add extra flags? i tried --use-exif and --force-gps invidually! but didnt work for me .
when i used --use-exif it got georefernced correctly but when i relocated GCPs lat long on orthomosaic , i got 1meter to 2 meters error.
with --force-gps flag got 1meter error. but i want it to reduce or should be less than 5cm.
how to achieve than. i tried each and every flags with gpu docker image, still didnt get expected results.
when i dont include --use-exif and --force-gps flags ,
i get this
“[INFO] 50 GCP points will be used for georeferencing”.
but still get the error of 1meter and more than that.
But for same dataset Agisoft gives good results with great absolute accuracy
When you are using GCPs, you do not need to force any extra flags.
Have you tried to adjust the --gps-accuracy flag if you’re confident in the mean GPS accuracy for the survey? We assume 10m by default.
GPS accuracy! sure in terms of what? how much i can use?
can i set it to 10cm ? and test?
Do you know your mean accuracy for the survey in X/Y/Z axes? If so, I would set it to the mean accuracy for Z (or 2x X/Y, as recommended by Stephen). So, if that’s 10cm, great!
this is how the orthomosaic got generated with GCPs. i didnt include any flags like use-exif or force-gps!
docker run --rm -v /home/sharu/datasets:/datasets --gpus all opendronemap/odm:gpu --project-path /datasets --feature-quality low --fast-orthophoto --orthophoto-no-tiled --cog --time --skip-band-alignment --gcp /datasets/gcp_list.txt
| [INFO] Generated coords file from GCP: WGS84 UTM 37S
GCPs are
It looks like you are not using GCPs properly. They are to. Be used with 3-5 images per GCP. It looks like you are instead defining a single location per GCP
This will not work.
ok, so i have marked 7 images for a single GCP, i will try using 4 images per GCPs and share u the result. should i do it?
3-5 images per GCP is recommended, and around 5 GCPs per site. It is recommended that they are evenly-distributed, so that normally means one in each corner and one roughly in the middle of the site.
Each GCP image tag for a given GCP must be referring to the same physical location.
Negative GSD
i run the following command still not got the expected ortho and it is not georeferenced, attached as below
got thiswarning also | [WARNING] Negative GSD estimated, this might indicate a flipped Z-axis.
docker run --rm -v /home/sharu/datasets:/datasets --gpus all opendronemap/odm:gpu --project-path /datasets project --feature-quality low --skip-3dmodel --orthophoto-no-tiled --cog --time --skip-band-alignment --gcp /datasets/gcp_list.txt
+proj=longlat +datum=WGS84 +no_defs +type=crs
40.01745652 -82.76516183 328.424 3246.2415 1384.3436 DJI_0512.JPG gcp1
40.01745652 -82.76516183 328.424 3231.2828 2236.3909 DJI_0513.JPG gcp1
40.01745652 -82.76516183 328.424 3714.6199 1259.4498 DJI_0443.JPG gcp1
40.01745652 -82.76516183 328.424 3719.7637 2011.2213 DJI_0444.JPG gcp1
40.01723723 -82.76351933 328.704 1336.7469 1239.7312 DJI_0032.JPG gcp2
40.01723723 -82.76351933 328.704 1376.9041 2124.8124 DJI_0033.JPG gcp2
40.01723723 -82.76351933 328.704 2910.7499 1037.3521 DJI_0035.JPG gcp2
40.01723723 -82.76351933 328.704 2980.6935 1785.0629 DJI_0036.JPG gcp2
40.01517735 -82.763876 326.079 3906.8882 1348.7201 DJI_0066.JPG gcp3
40.01517735 -82.763876 326.079 3953.1659 2182.3327 DJI_0067.JPG gcp3
40.01517735 -82.763876 326.079 2893.4966 1672.2021 DJI_0068.JPG gcp3
40.01517735 -82.763876 326.079 2863.1006 2381.0874 DJI_0069.JPG gcp3
40.01532619 -82.76530394 327.245 2660.4947 1884.5368 DJI_0477.JPG gcp4
40.01532619 -82.76530394 327.245 2665.2383 2737.0009 DJI_0478.JPG gcp4
40.01532619 -82.76530394 327.245 2649.8769 1017.6906 DJI_0476.JPG gcp4
40.01532619 -82.76530394 327.245 1681.8977 1638.2411 DJI_0409.JPG gcp4
40.01612577 -82.76453392 328.648 3242.9772 455.0880 DJI_0283.JPG gcp5
40.01612577 -82.76453392 328.648 3164.5017 1323.0506 DJI_0284.JPG gcp5
40.01612577 -82.76453392 328.648 3088.1117 2209.7927 DJI_0285.JPG gcp5
40.01612577 -82.76453392 328.648 3843.0491 1885.4432 DJI_0256.JPG gcp5
Can you try with --feature-quality high or ultra?
will it require more memory?
ok now running with
docker run --rm -v /home/sharu/datasets:/datasets --gpus all opendronemap/odm:gpu --project-path /datasets project --feature-quality high --skip-3dmodel --orthophoto-no-tiled --cog --time --skip-band-alignment --gcp /datasets/gcp_list.txt
waiting for good results!
I wonder if i use --use-exif flag i got georeferenced ortho but GCPs absolute accuracy is in meters!
Yes, it will, but that type of limited reconstruction (passing --crop 0 might also help) in the orthophoto usually indicates not finding sufficient tiepoints, and using a higher --feature-quality will usually help this.
kindly reply on this
docker run --rm -v /home/sharu/datasets:/datasets --gpus all opendronemap/odm:gpu --project-path /datasets project --feature-quality high --crop 0 --skip-3dmodel --orthophoto-no-tiled --cog --time --skip-band-alignment --gcp /datasets/gcp_list.txt
:pensive:
