Recently I have more issues with gps misalignment, ie 100s of feet to the right vs google map and cutting off certain slices in the orthomap/pointcloud.
I am flying at least 70% overlap, DJI L1D 2c Hasselblad camera.
I run standard parameters in lightning odm and my docker odm.
I also tried with camera lens setting brown, same result unfortunately
ODM
Comparison - dronedeploy renders well.
Thank you for any pointers to fix.
The link to the dataset
Google Drive: Sign-in -
Copy/paste task output
[INFO] Initializing ODM - Sat May 09 07:41:53 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] mve_confidence: 0.6
[INFO] name: cc50c2b0-110a-485b-ad15-a112b68385d5
[INFO] optimize_disk_space: True
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0.01
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/cc50c2b0-110a-485b-ad15-a112b68385d5/images
[INFO] Loading 205 images
[INFO] Wrote images database: /var/www/data/cc50c2b0-110a-485b-ad15-a112b68385d5/images.json
[INFO] Found 205 usable images
[INFO] Parsing SRS header: WGS84 UTM 55S
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] [‘use_exif_size: no’, ‘feature_process_size: 2048’, ‘feature_min_frames: 8000’, ‘processes: 8’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 640’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘bundle_common_position_constraints: no’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /usr/bin/env python2 /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/var/www/data/cc50c2b0-110a-485b-ad15-a112b68385d5/opensfm”
2020-05-09 07:41:56,142 INFO: Extracting EXIF for DJI_0571.JPG -
Did you fine tune any parameters? Which ones?
No
