Ortho photo is good when build a part of the area, bad when build all the whole area
Hi everyone,
I am using webodm to build ortho photo for solar power plant.
Because the plant is so large, i flew the drone twice to take picture on 2 parts of plant.
If i run webodm for each separate part, the result is good but for the whole plant (including 2 parts), the bottom part of part 1 will be bad.
My WebODM:
  • API Version: 2.2.0
  • Engine: odm
  • Engine version: 2.7.2
Settings:
auto-boundary: true, dsm: true, feature-quality: ultra, feature-type: hahog, ignore-gsd: true, min-num-features: 18000, optimize-disk-space: true, pc-quality: low
The input and result is saved here:
https://drive.google.com/drive/folders/1uH4DxAe79Sc53QnVPUCV2HThVbq6jnHM?usp=sharing
What should i do to fix it?
Thank you in advance for any help
It comes out ok with the below settings.
813 images 01:21:38
|Options:|auto-boundary: true, dem-resolution: 2.0, dsm: true, dtm: true, feature-quality: ultra, gps-accuracy: 8, mesh-octree-depth: 12, mesh-size: 250000, min-num-features: 12000, orthophoto-resolution: 2, pc-filter: 5, pc-geometric: true, pc-quality: ultra, resize-to: -1, smrf-threshold: 2.5, use-3dmesh: true|
|Average GSD:|10.64 cm|
|Area:|363,157.78 m²|
|Reconstructed Points:|44,394,029|
It works well.
Thank you. You saved my day!
Could you tell me what was wrong and what is the key point to fix or improve it?
Point cloud quality would be important. The images were quite small, without a lot of detail to start with, so I used ultra to retain as much of that detail as possible.
pc_geometric may have helped, as the PV array is not dissimilar to rows of buildings.
It is rarely useful to use ignore-gsd, and it often causes a crash, but that doesn’t appear to have been a problem here.
I understood. Thank you for your help.
