I only tried that on the third attempt, it made no real difference, the grey areas were there on the first 2 attempts, which had these settings:
99 images 01:18:29
Options: auto-boundary: true, boundary: {“type”:“FeatureCollection”,“features”:[{“type”:“Feature”,“properties”:{},“geometry”:{“type”:“Polygon”,“coordinates”:[[[151.0513673722744,-31…], etc}, dsm: true, dtm: true, feature-quality: ultra, gps-accuracy: 4, mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 10000, orthophoto-resolution: 1, pc-geometric: true, pc-quality: high, pc-rectify: true, use-3dmesh: true
Average GSD: 0.69 cm
Area: 1,150.35 m²
Reconstructed Points: 9,611,489
and then I took more images, but that didn’t help
177 images 00:23:32
Created on: 27/12/2021, 18:08:19
Options: auto-boundary: true, boundary: {“type”:“FeatureCollection”,“features”:[{“type”:“Feature”,“properties”:{},“geometry”:{“type”:“Polygon”,“coordinates”:[[[151.0513673722744,-31. etc}, dem-resolution: 1, dsm: true, gps-accuracy: 5, mesh-octree-depth: 12, mesh-size: 300000, min-num-features: 10000, orthophoto-resolution: 1, pc-geometric: true, pc-quality: high, pc-rectify: true, use-3dmesh: true
Average GSD: 0.91 cm
Area: 871.31 m²
Reconstructed Points: 4,920,304
I’ll try that, it doesn’t take too long.
I tried Reality Capture, the 3D model had a similar problem with the shade cloth. although the result was slightly better, and the ortho didn’t have any holes in it, on the shade cloth, ground or house roof.
