Orbital images - vs vertical images in ODM
Hi, I wanted to know if odm takes in to consideration when building the 3d objects any orbital images. I’m using a Mavic with Drone Deploy to set up the mission and one of the options there is at the end of taking all the vertical images do I also want angled orbital images as well, which I’m guessing Drone Deploys servers then use for enhancing the 3d model. So question is, does ODM utilize these images as well or is there no point in taking them and adding them to a project?
Yes ODM will take into consideration those images. For 3D especially, it’s recommended to have orbital images.
do i need to notate somehow to the run process which images those are? or does it get it automagically?
#4
It detects them automatically.
