Option to select algorithm plant health
Hello ,
Very happy to begin use Open drone map. Trying to execute some indices in my dji images , i didn’t see the option to select and see others algortihms. My situation in the belong image
I just can select orthophoto and plant health and i would to select others indices
I need help
Regards
Click on the ‘layers’ option that looks like a stack of paper directly below ‘Plant Health’. From there you will be able to choose different vegetation indices. Since I assume you’ve taken RGB images you will only be able to reliably use indices that use Red, Green, and Blue light!
Thank a lot @RainyRockies :slight_smile:That is working.
Regard
