First of all, I want to say I appreciate this community as it has been an invaluable resource for me and my mapping journey! Thank you all.
On to the questions at hand: I have recently acquired a Mavic 3 Enterprise with Network RTK.
and I have begun the process of nailing down a correct workflow for producing the highest possible quality ortho’s and DEM’s. A report for a recent mission can be viewed here:
PDF: report.pdf - Google Drive
TXT: task_output.txt - Google Drive
This is the first RTK dataset I have processed. I use WebODM and Lightning for processing, and I am using DJI Pilot 2 for the flight planning which has some restrictions. I flew using the DJI pre-programmed “oblique” flight template which flies 5 different paths, with path 1 being nadir, and 2-5 being oblique. Oblique angle was 70 degrees. Front and side overlap 83%. All from 110 m altitude.
Looking at the report, I am happy to see the GPS errors are within expected tolerances. However, are the relative 3D errors a little higher than expected?
For verification I have overlayed a conventional topo survey over the DEM and compared elevations and the errors seem to agree with the 3D error in this report, in the area of 0.1 to 0.3 meters.
Am I just expecting too much for a dataset produced at 110 m with no GCP’s? Or is there something going on here? Would GCP’s improve this type of error?
Does anyone have any suggestions for how I might tighten this relative error to 0.05 m or better? Running on Ultra is not an option because I don’t have any other way to process than Lightning.
I appreciate any comments or suggestions. Additional data can be shared.
