i downloaded a docker image today with ODM and GPU support.
When i run it on a couple of images, i get the following exception:
[INFO] running "/code/SuperBuild/install/bin/FPCFilter" --input "/code/opensfm/reconstruction.ply" --output "/code/odm_filterpoints/point_cloud.ply" --concurrency 32 --meank 16 --std 5.0 --boundary "/tmp/tmp_43tn96h.boundary.json"
*** FPCFilter - v0.1 ***
?> Parameters:
input = /code/opensfm/reconstruction.ply
output = /code/odm_filterpoints/point_cloud.ply
std = 5
meanK = 16
boundary = 140 polygon vertexes
concurrency = 32
verbose = no
-> Setting num_threads to 32
-> Cropping
-> Done cropping in 0.4552s
?> Skipping sampling
-> Statistical filtering
?> Done in 0.2s
-> Writing output
?> Done in 0.03291s
?> Pipeline done in 0.6882s
[INFO] Writing ODM Mesh file in: /code/odm_meshing/odm_mesh.ply
[INFO] running "/code/SuperBuild/install/bin/PoissonRecon" --in "/code/odm_filterpoints/point_cloud.ply" --out "/code/odm_meshing/odm_mesh.dirty.ply" --depth 10 --pointWeight 4.0 --samplesPerNode 1.0 --threads 31 --bType 2 --linearFit
[ERROR] Src/PoissonRecon.cpp (Line 1144)
main
Ply file does not contain normals
[WARNING] PoissonRecon failed with 15 threads, let's retry with 7...
[INFO] running "/code/SuperBuild/install/bin/PoissonRecon" --in "/code/odm_filterpoints/point_cloud.ply" --out "/code/odm_meshing/odm_mesh.dirty.ply" --depth 10 --pointWeight 4.0 --samplesPerNode 1.0 --threads 15 --bType 2 --linearFit
main
[WARNING] PoissonRecon failed with 7 threads, let's retry with 3...
[INFO] running "/code/SuperBuild/install/bin/PoissonRecon" --in "/code/odm_filterpoints/point_cloud.ply" --out "/code/odm_meshing/odm_mesh.dirty.ply" --depth 10 --pointWeight 4.0 --samplesPerNode 1.0 --threads 7 --bType 2 --linearFit
main
[WARNING] PoissonRecon failed with 3 threads, let's retry with 1...
[INFO] running "/code/SuperBuild/install/bin/PoissonRecon" --in "/code/odm_filterpoints/point_cloud.ply" --out "/code/odm_meshing/odm_mesh.dirty.ply" --depth 10 --pointWeight 4.0 --samplesPerNode 1.0 --threads 3 --bType 2 --linearFit
main
[WARNING] PoissonRecon failed with 1 threads, let's retry with 0...
[INFO] running "/code/SuperBuild/install/bin/PoissonRecon" --in "/code/odm_filterpoints/point_cloud.ply" --out "/code/odm_meshing/odm_mesh.dirty.ply" --depth 10 --pointWeight 4.0 --samplesPerNode 1.0 --threads 1 --bType 2 --linearFit
main
[INFO] running "/code/SuperBuild/install/bin/OpenMVS/ReconstructMesh" -i "/code/odm_meshing/odm_mesh.dirty.ply" -o "/code/odm_meshing/odm_mesh.ply" --remove-spikes 0 --remove-spurious 20 --smooth 0 --target-face-num 600000 -v 0
/code/SuperBuild/install/bin/OpenMVS/ReconstructMesh: error while loading shared libraries: libcuda.so.1: cannot open shared object file: No such file or directory
Child returned 127
File "/code/opendm/types.py", line 346, in run
[Previous line repeated 2 more times]
File "/code/opendm/types.py", line 327, in run
File "/code/stages/odm_meshing.py", line 24, in process
File "/code/opendm/mesh.py", line 208, in screened_poisson_reconstruction
system.run('"{reconstructmesh}" -i "{infile}" '
opendm.system.SubprocessException: Child returned 127
[ERROR] The program exited with a strange error code. Please report it at https://community.opendronemap.org
I am running it with the following command:
C:\Users\u123>docker run -it --rm -v "d:\site2:/code/images" -v "d:\site2\orthophoto:/code/odm_orthophoto" -v "d:\site2\georeferencing:/code/odm_georeferencing" -v "d:\site2\report:/code/odm_report" opendronemap/odm:gpu --fast-orthophoto --pc-quality high --pc-filter 5 --pc-geometric --pc-rectify --resize-to -1 --use-3dmesh --matcher-neighbors 12 --mesh-octree-depth 7 --mesh-size 300000 --orthophoto-resolution 1 --auto-boundary --feature-quality high --dem-resolution 2 --dsm
