'Official' feature request - Saving a Navigation/Animation path
This request has been mentioned in another post of mine but here it is to make it official, in case it slips through the net:
I would like to ask for a means to save a navigation path setup to make an animation of a 3d model.
At the moment one can spend a long time devising one but if you move back to the Dashboard then when you return it’s all gone.
As part of that request, it would be helpful to see in the list in the left-hand panel which control point is being selected when you touch one on the model, so one can delete the correct one.
An Undo/Redo feature would be helpful too and probably a means to export the navigation path or set of points, rather like one can export Google Earth Maps points as a KML file.
Thank you
