I have been trying to use ODM and ClusterODM for distributing image merging workload across multiple systems. I managed to do it between local PCs. But when I tried aws autoscaling, it is always getting stuck at “Downloading assets for submodel”. Here is what I did
- I have a public s3 bucket.
- I am running ODM, clusterODM and a single dummy locked nodeODM in an instance(m5ad.4xlarge)
- I took the default aws settings and tweaked the security and bucket address and aws-image id settings. Also added security group where port 3000,3001 and 22 inbound traffic are allowed.
- Then I started running a task with 1001 images.
- it created 2 spot instances t3a.xlarge. I monitored CPU usage and such.
- After a while, when it started downloading the result from each instance, it gets stuck and stays there.
- I check the s3 bucket. it seems two new folders were created containing all.zip file.
Also, the instances are getting terminated so I think the download to s3 is successful.
I wonder if I am doing something wrong.
