Hello everyone, in the place I work, after some time coding we developed an up-to-date tutorial to install the awesome ODM in windows 10 it works really good. Follow this tutorial please:
kind regards.
kind regards.
@Saijin_Naib
Very nice! Perhaps you might be interested in contributing this to our docs and/or README on GitHub - OpenDroneMap/docs: 🎉 Contribute to OpenDroneMap's documentation! Read how below! 🎉 / GitHub - OpenDroneMap/ODM: A command line toolkit to generate maps, point clouds, 3D models and DEMs from drone, balloon or kite images. 📷 ?
Yes for sure! could do refer to the link for me please? It works with WSL and WSL2, I think this could solve lots of compatibilities for ODM and increase the community of this awesome tool.
A pull request on GitHub - OpenDroneMap/docs: 🎉 Contribute to OpenDroneMap's documentation! Read how below! 🎉 would do the trick. It’s nice to see this contribution.
This is great!
Hi, thanks for the post. I am trying to install ODM in windows as is described in the video. when I type bash c1804.sh says no such file or directory, and don’t know how to install it. Any advice is welcome. Thanks
If you can wait it out, we’re currently underway doing some serious infrastructure work to get WSL images and SNAPs made, along with library/dependency upgrades!
Thanks Saijin. I am kind of hurry, I 'been trying for a couple of days how to install and have proved a bunch of alternatives (from a vmware-runing Ubuntu, from Docker), and I couldn’t.
Unfortunately, I’ve not had success making a WSL image myself, hence the above funding drive to get someone really smart to figure it out for all of us
I’d say if you need results immediately, take advantage of WebODM Lightning by UAV4Geo / @pierotofoy.
ooh, eck, don’t build me up too high or I’ll get an inflated ego
Hi, I am trying now through a VirtualMachine. There, I installed Ubuntu 20.04 and I am trying to install ODM.
These are the results:
[email protected]:~$ docker-compose version
docker-compose version 1.25.0, build unknown
docker-py version: 4.1.0
CPython version: 3.8.5
OpenSSL version: OpenSSL 1.1.1f 31 Mar 2020
[email protected]:~$ sudo pip install docker-compose
[sudo] password for jkairo:
sudo: pip: command not found
[email protected]:~$ $ git clone GitHub - OpenDroneMap/WebODM: User-friendly, commercial-grade software for processing aerial imagery. 🛩
$: command not found
[email protected]:~$ git clone GitHub - OpenDroneMap/WebODM: User-friendly, commercial-grade software for processing aerial imagery. 🛩
fatal: destination path ‘WebODM’ already exists and is not an empty directory.
[email protected]:~$ cd WebODM
[email protected]:~/WebODM$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
ERROR: Couldn’t connect to Docker daemon at http+docker://localhost - is it running?
If it’s at a non-standard location, specify the URL with the DOCKER_HOST environment variable.
Advices are welcome!
Thanks in advance, Jairo
You will have the best luck with either 16.04LTS for OpenDroneMap 1.x, or 18.04LTS for OpenDroneMap 2.x.
20.04LTS is currently unsupported.
Yes, if 20.04 is required, run it through docker.
thanks!!
I guess the critical question is, should I be updating the Windows install directions at docs.opendronemap.org to match https://github.com/OpenDroneMap/odm/README.md? Are we far enough along?
Nevermind: these are directions for ODM and those are directions for WebODM… .
