ODM:GPU on radeon
Hi Folks,
regarding the topic i find on the github:
GPU Acceleration
ODM has support for doing SIFT feature extraction on a GPU, which is about 2x faster than the CPU on a typical consumer laptop.
i’am trying to run this. unfortunatly i have a Radeon GPU - RX570
all info like i find about “docker + gpu” is connecting to docker with NVIDIA/CUDA
but on readme on github are info:
The SIFT GPU implementation is OpenCL-based, so should work with most graphics card (not just NVIDIA).
i tryed two way:
  1. installed newest radeon drivers from amd website
    (instaling by ./amdgpu-pro-install --opencl=rocr,legacy
  2. installed rocm drivers
in both case i can see that the drivers are correctly installed and my GPU support OpenCL 1.2 and OpenCL C 2.0
but unfortunately in both case when i trying run the ODM i get:
docker: Error response from daemon: could not select device driver "" with capabilities: [[gpu]].
is there someone who run GPU acceleration on Radeon GPU and can share self experience?
all best
Can you do me a favor and install clinfo inside the ODM docker container and paste the output? I’m curious what it turns up.
now i’am on the rocm drivers,
the /opt/rocm/opencl/bin/clinfo
shows:
Number of platforms: 1
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 2.0 AMD-APP (3275.0)
Platform Name: AMD Accelerated Parallel Processing
Platform Vendor: Advanced Micro Devices, Inc.
Platform Extensions: cl_khr_icd cl_amd_event_callback
Number of devices: 1
Device Type: CL_DEVICE_TYPE_GPU
Vendor ID: 1002h
Board name: Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
Device Topology: PCI[ B#11, D#0, F#0 ]
Max compute units: 32
Max work items dimensions: 3
Max work items[0]: 1024
Max work items[1]: 1024
Max work items[2]: 1024
Max work group size: 256
Preferred vector width char: 4
Preferred vector width short: 2
Preferred vector width int: 1
Preferred vector width long: 1
Preferred vector width float: 1
Preferred vector width double: 1
Native vector width char: 4
Native vector width short: 2
Native vector width int: 1
Native vector width long: 1
Native vector width float: 1
Native vector width double: 1
Max clock frequency: 1244Mhz
Address bits: 64
Max memory allocation: 3650722200
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 8
Max image 2D width: 16384
Max image 2D height: 16384
Max image 3D width: 16384
Max image 3D height: 16384
Max image 3D depth: 8192
Max samplers within kernel: 26591
Max size of kernel argument: 1024
Alignment (bits) of base address: 1024
Minimum alignment (bytes) for any datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: Yes
Round to +ve and infinity: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: Read/Write
Cache line size: 64
Cache size: 16384
Global memory size: 4294967296
Constant buffer size: 3650722200
Max number of constant args: 8
Local memory type: Scratchpad
Local memory size: 65536
Max pipe arguments: 16
Max pipe active reservations: 16
Max pipe packet size: 3650722200
Max global variable size: 3650722200
Max global variable preferred total size: 4294967296
Max read/write image args: 64
Max on device events: 1024
Queue on device max size: 8388608
Max on device queues: 1
Queue on device preferred size: 262144
SVM capabilities:
Coarse grain buffer: Yes
Fine grain buffer: Yes
Fine grain system: No
Atomics: No
Preferred platform atomic alignment: 0
Preferred global atomic alignment: 0
Preferred local atomic alignment: 0
Kernel Preferred work group size multiple: 64
Error correction support: 0
Unified memory for Host and Device: 0
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue on Host properties:
Out-of-Order: No
Profiling : Yes
Queue on Device properties:
Out-of-Order: Yes
Profiling : Yes
Platform ID: 0x7f0e3d874dd0
Device OpenCL C version: OpenCL C 2.0
Driver version: 3275.0 (HSA1.1,LC)
Version: OpenCL 1.2
Extensions: cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_depth_images cl_amd_copy_buffer_p2p cl_amd_assembly_program
Thanks for that!
I’m at my knowledge limit here, unfortunately.
It looks like it is showing up properly, so that’s a good start, at least.
and clinfo on radeon drivers:
Number of platforms 1
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.1 AMD-APP (3224.4)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Platform Host timer resolution 1ns
Platform Extensions function suffix AMD
Number of devices 1
Device Name Ellesmere
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 1.2 AMD-APP (3224.4)
Driver Version 3224.4
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Board Name (AMD) Radeon RX 570 Series
Device Topology (AMD) PCI-E, 0b:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 32
SIMD per compute unit (AMD) 4
SIMD width (AMD) 16
SIMD instruction width (AMD) 1
Max clock frequency 1244MHz
Graphics IP (AMD) 8.0
Device Partition (core)
Max number of sub-devices 32
Supported partition types None
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 1024x1024x1024
Max work group size 256
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple 64
Wavefront width (AMD) 64
Preferred / native vector sizes
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 3823812608 (3.561GiB)
Global free memory (AMD) 3714608 (3.543GiB)
Global memory channels (AMD) 8
Global memory banks per channel (AMD) 16
Global memory bank width (AMD) 256 bytes
Error Correction support No
Max memory allocation 3051235942 (2.842GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 2048 bits (256 bytes)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 128
Max number of write image args 8
Local memory type Local
Local memory size 32768 (32KiB)
Local memory syze per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 3051235942 (2.842GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Prefer user sync for interop Yes
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 1621022911763446712ns (Fri May 14 22:08:31 2021)
Run OpenCL kernels Yes
Run native kernels No
Thread trace supported (AMD) Yes
Number of async queues (AMD) 2
Max real-time compute queues (AMD) 0
Max real-time compute units (AMD) 1986098990
SPIR versions 1.2
printf() buffer size 4194304 (4MiB)
Built-in kernels (n/a)
Device Extensions cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_amd_bus_addressable_memory cl_khr_spir cl_khr_gl_event
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, …) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, …) No platform
clCreateContext(NULL, …) [default] No platform
clCreateContext(NULL, …) [other] Success [AMD]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
and what i notice now - on the rocm drivers i can not run Davinci Resolve - they don’t find my GPU,
but on the radeon drivers Davinci works well
davinci
so the drivers are 100% good installed and work well.
I have same issue here.
But I find the problem.
AMD website says these GPU doesn’t support in win 10 .
Blockquote
My experience so far running it on imac Radeon Pro 570X 4 GB: Looks like it is searching for a nvidia-container hook.
Any suggestions or thoughts on how to successfully run it with AMD Radeon?
Status: Downloaded newer image for opendronemap/odm:gpu
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request: unknown.
