I am having an issue running ODM when the install path has a ’ character in it. This is the output I get for the install path “C:\Temp\Tes’t\ODM”. I have a case where a Windows user name has that character, which makes it impossible to install ODM anywhere inside that user’s directory.
It seems to be similar to this thread (Non ascii character in ODM Install Path), but I guess that this specific issue hasn’t been fixed there.
OUTPUT:
/ ____ _____ __ __
| / __ \ | __ \ | / | |
| _/ |/ || || |
__________________________/
version: 2.8.6Traceback (most recent call last):
File “C:\Temp\Tes’t\ODM\run.py”, line 15, in
from opendm.utils import get_processing_results_paths, rm_r
File “C:\Temp\Tes’t\ODM\opendm\utils.py”, line 3, in
from opendm.photo import find_largest_photo_dims
File “C:\Temp\Tes’t\ODM\opendm\photo.py”, line 17, in
from opendm import get_image_size
File “C:\Temp\Tes’t\ODM\opendm\get_image_size.py”, line 2, in
import cv2
File “C:\Temp\Tes’t\ODM\venv\lib\site-packages\cv2_init_.py”, line 96, in
bootstrap()
File “C:\Temp\Tes’t\ODM\venv\lib\site-packages\cv2_init_.py”, line 59, in bootstrap
load_first_config([
File “C:\Temp\Tes’t\ODM\venv\lib\site-packages\cv2_init_.py”, line 53, in load_first_config
exec_file_wrapper(fpath, g_vars, l_vars)
File “C:\Temp\Tes’t\ODM\venv\lib\site-packages\cv2\load_config_py3.py”, line 8, in exec_file_wrapper
code = compile(f.read(), os.path.basename(fpath), ‘exec’)
File “config-3.8.py”, line 1
PYTHON_EXTENSIONS_PATHS = [r’C:\Temp\Tes’t\ODM\venv\lib\site-packages\cv2\python-3.8’] + PYTHON_EXTENSIONS_PATHS
SyntaxError: invalid syntax
