ODM docker processing fails while runing the same from WebODM works
Hello!
I’m having problem while processing images by simple call of docker command:
docker run -u 1000:1000 -ti --rm -v "${PWD}":/datasets opendronemap/odm:latest  --auto-boundary --cog --crop 3 --dem-decimation 1 --dem-gapfill-steps 3 --dem-resolution 5 --depthmap-resolution 640 --dsm --end-with odm_postprocess --feature-quality high --feature-type sift --gps-accuracy 10 --matcher-neighbors 8 --matcher-type flann --max-concurrency 16 --merge all --mesh-octree-depth 11 --mesh-size 200000 --min-num-features 10000 --orthophoto-compression DEFLATE --orthophoto-resolution 5 --pc-ept --pc-filter 2.5 --pc-quality medium --pc-sample 0 --primary-band auto --radiometric-calibration none --resize-to 2048 --sfm-algorithm incremental --smrf-scalar 1.25 --smrf-slope 0.15 --smrf-threshold 0.5 --smrf-window 18.0 --split 999999 --split-overlap 150 --texturing-data-term gmi --texturing-outlier-removal-type gauss_clamping --texturing-tone-mapping none --project-path /datasets --rerun-all project_small
It fails with an error:
                "[ERROR] Src/CoredMesh.h (Line 166)",
                "BufferedReadWriteFile",
                "Failed to open file: ./PR__points_DpGohO"
At the same time, processing from WebODM proceed without any problem. I used the same parameters, copied from WebODM’s default profile.
Here are logs from ODM run by docker:
And logs from proper processing run by WebODM:
I want to publish a testing set of images, but I’m waiting now for permission from the owner.
What is the difference between running ODM using docker and by WebODM?
Why it may fail?
I’ve found what was the problem!
I run docker container’s ODM processing as not root user and in this case processing failed…
Should I report a bug for this? There should be possibility to run it as a normal user.
If I understand the problem, you will need to add your user to the docker group:
sudo usermod -aG docker ${USER}
Then log out and log back in. This is generally preferred to running docker as the root user.
No, that’s not my problem. My system (host) user is already added into docker group.
I want to run docker container processing as a user with id 1000 and group 1000 (not root). In this case, docker container’s user doesn’t have root rights, and it creates output files in a volume with user (1000:1000) as an owner.
There is an issue with ODM processing as non-root user, probably during processing there are written some temporary files in a location restricted for root instead of e.g. /tmp. That’s my guess.
Ah, I don’t know then. I have never tried to run docker rootless, I always just assumed you’d want to use singularity or podman if you wanted rootless. Perhaps it is strictly speaking a bug, though I try not to think this deeply about containers :D. Feel free to open a bug report at GitHub - OpenDroneMap/ODM: A command line toolkit to generate maps, point clouds, 3D models and DEMs from drone, balloon or kite images. 📷 if you think it is. Bonus points if it is something you could provide a patch for.
