If one were to set up a super outfitted machine on Azure or AWS would WebODM be; 1 able to be installed there and 2 able to use all the cores and RAM you had configured into it? Please advise. M
Yes, its possible to install them on Azure Machine. I have tried by using a Ubuntu VM with xfce(UI) installed through bash.
And with the use of docker image of opendronemap/webodm, it is possible to fully use the cores and RAM allocated to the system. They by default use the complete system RAM and cores, unless you specify docker images to make a limited usage.
Here is the documentation link to help you get started.
Good Luck!
